Handbrake Cable Route And Brackets
20 replies to this topic
#1 rodandtom
rodandtom
  • 998 posts
Posted 28 October 2015 - 03:45 PM
Hi,
has anyone got a picture of the brackets mounted to the subframe for holding the tensioning spring in place at the rear drums please?
Also, and I do know that this is probably a stupid question, but do the handbrake quadrants go on the top of the radius arm or below it?
Thanks,
Rod
#2 nicklouse
  • 18,711 posts
Posted 28 October 2015 - 04:00 PM
Mmm the spring brackets are on the drum back plate.
and under.
#3 rodandtom
rodandtom
  • 998 posts
Posted 28 October 2015 - 04:15 PM
Ok so the cable goes through the subframe to the quadrants underneath the radius arm. How do the cables not rub on the subframe? That's why I was asking about them going above the radius arm.
Do you have a photo of where the spring brackets sit please?
Thanks,
Rod
#4 Batmini
Batmini
  • 378 posts
Posted 28 October 2015 - 04:44 PM
This any use ?
#5 rodandtom
rodandtom
  • 998 posts
Posted 28 October 2015 - 04:47 PM
That is useful thanks but what I need to see is how the cable gets routed. I am assuming it goes through the subframe or is it meant to go under it?
Thats the only thing this doesn't show.
Thanks,
Rod
#6 joshw
joshw
  • 152 posts
Posted 28 October 2015 - 04:53 PM
http://www.classicmi...om/the-rebuild/
Quite a few photos at the bottom of this page any good?
#7 Batmini
Batmini
  • 378 posts
Posted 28 October 2015 - 05:00 PM
Was just digging out the same pics from mine, saved me. Thanks Josh
#8 rodandtom
rodandtom
  • 998 posts
Posted 28 October 2015 - 09:39 PM
That does tell me that it runs through the hole in the subby - thats fine thanks -but surely it rubs on the subframe? The quadrant is below the radius arm so it must rub - doesn't it?
Rod
#9 nordicmini
nordicmini
  • 293 posts
Posted 28 October 2015 - 09:45 PM
quadrant goes on top of the radius arm
#10 GraemeC
GraemeC
  • 7,440 posts
Posted 28 October 2015 - 09:48 PM
No it doesn't!
#11 nicklouse
  • 18,711 posts
Posted 28 October 2015 - 09:55 PM
Rod
Just about every question is answered in the Haynes manual. Get one it will have paid for its self in a day or so.
#12 spiguy
spiguy
  • 1,537 posts
Posted 28 October 2015 - 11:07 PM
It shouldn't rub (I presume you are meaning on the lower webbings).
#13 rodandtom
rodandtom
  • 998 posts
Posted 29 October 2015 - 06:46 PM
Hi
I meant the cable will rub on the edge of the hole in the subframe. It runs through the large hole in the subby but because of the quadrant being on the bottom of the radius arm. I wanted to check that the wire was running through the correct place and to avoid it rubbing if at all possible.
Rod
#14 rodandtom
rodandtom
  • 998 posts
Posted 01 November 2015 - 05:52 PM
Handbrake sorted.
I was guilty of what my wife calls 'boy looking' and I hadn't seen the smaller hole behind the larger hold - and that is where the handbrake cable actually goes.
All done now. As it turns out I didn't need to use the brackets that bolt on to the rear drum plates. I have the later set up that just requires you to use a clevis pin straight on to the arm that comes out of the back plate.
Handbrake is all in and sorted.
Done and thanks for everyone's input.
Rod
#15 Udo
Udo
  • 1,670 posts
Posted 01 November 2015 - 06:12 PM
You still need the brackets as they are the "stop" for the spring which ensures the lever moves back and so releases the handbrake
I've only ever seen one version of the brackets/cable/spring so fairly confident there isn't a "later" version of this area, mk1's being slightly different on the cables
Edited by Udo, 01 November 2015 - 06:14 PM.
