Zcars Parts?
Posted 04 November 2015 - 08:54 PM
Posted 05 November 2015 - 07:36 AM
Posted 05 November 2015 - 10:05 AM
Posted 05 November 2015 - 10:29 AM
As far as I am aware mate yes they have shut the doors luckily for me I only need a fue parts I have been told by zcars they will let people know where to obtain parts but I have tried calling them but with no answer
Too bad!!!Im really glad didn`t order the vtec race-kit a month ago. Would be Money up in smoke:(
Posted 05 November 2015 - 11:41 AM
When you say the fuel and water systems, do you mean the whole thing or do you have some of the parts?
Posted 05 November 2015 - 01:09 PM
Posted 05 November 2015 - 01:31 PM
I can supply you the sloped tank dimensions.
From memory - the majority of the piping for coolant is 28mm, the pipes that fit the motor are 32mm but that would be worth double checking. You can get 32-28 reducer pipes.
I'd have to dig out the part numbers for the fuel system bits n bobs.
I'll get back to you.
Posted 05 November 2015 - 01:43 PM
Posted 05 November 2015 - 01:47 PM
You need a bleed like this, send that to the expansion tank.
This will help when it comes to wiring the wiper motor up:
Fuel tank dims - it'll need tabs welding on the bottom edges to fix it to the frame, don't know that size but it'll be 180 by something....:
This will help with the fuel system setup:
Posted 05 November 2015 - 03:17 PM
Posted 05 November 2015 - 03:27 PM
Threads on a rose joint need to be a minimum of 1.5 times the diameter of the thread inside the fitting, so those rose joints are 5/8" male thread in the trailing arm and need to be a minimum of approx 24mm inside.
Not knowing your kit its really difficult for me to say, sounds like the difference might have to be made up with the arches, less than ideal....
As you go through the build you'll find a lot of things like that will crop up. Its a different world from building a Caterham or other kit car where you get every nut and bolt and instructions....
Posted 05 November 2015 - 04:27 PM
Posted 05 November 2015 - 07:21 PM
Hello i'am Normal from France(sorry for my english).
My car Volvo ZCARS race full home build:
To help all Zcars builders:
Front hubs: OEM MINI
Edited by Normal, 05 November 2015 - 07:43 PM.
Posted 06 November 2015 - 05:54 AM
Posted 06 November 2015 - 12:16 PM
You could use a Walbro fp604 or a Bosch 044.
Thats two pumps are external type and you must use a fuel pressure régulator to have the same pressure as original pressure (normaly 3.5Bars)
