is it totaly nessisary to take the big lump out of my bulkhead if i do go turbo
why do you have to cut it out
and also is the t3 the biggest turbo that will fit ?
sutty
ps was nice to se the mini forum members at drag wars
bulkhead
Sutty01
, Jul 18 2004 08:38 PM
8 replies to this topic
Posted 18 July 2004 - 08:38 PM
Posted 18 July 2004 - 10:53 PM
If you are fitting the Metro Turbo type set-up then it is essential to cut the bulkhead. This allows clearance for the Turbo, which is mounted behind the engine.
You can't fit the engine if you don't cut the bulkhead.
If you don't want to cut the bulkhead, check out Mirage Motorsport with their manifold kit you can fit a T2 Turbo without any shell mods.
There will be no benefit in fitting a larger Turbo than the T3, this unit will provide enough effective boost for over 200+hp. More than adequate for any A-Series.
Phil. :grin:
Phil. :grin:
Posted 19 July 2004 - 10:09 PM
wil fitting this kit in any way affect the performance and isnt the T2 much smaller so wont give as effective boost ?
Posted 19 July 2004 - 10:28 PM
How much boost are you planning on running ?, the Renault 5 unit will produce efficient boost up to around 17 psi or so ....
Phil. :grin:
Phil. :grin:
Posted 19 July 2004 - 10:34 PM
well im planing to do this in a few years time but ill be going all out on it
Geting best qwality parts
including 6 speed bod 4 pin dif straight cuts all over play bushing mounts pistons cams heaad valves gaskets cooling ( intercooler)
you get my point
you get my point
Posted 20 July 2004 - 07:22 AM
Phill is about spot on.
If you don't want to cut your bulkhead use a T2 and a Mirage manifold. I spoke to garrett and they said that a T2 with uprated bearings woud be happy to make 25psi, I think that would be enough (I currently run 19).
Having said that I have a T3 on a metro manifold and I didn't put a box in, basically I used a big hammer and "altered" the shape of the bulkhead. However, this is a bodge and my engine is solid mounted so it dosen't move; so the fact that the turbo is only 5mm (max.) from the bulkhead isn't a problem. When I get around to re-sheling the car I will be putting a bulkhead box in.
Wil
Wil
Posted 20 July 2004 - 07:52 PM
phil , will wont the "small turbo" escort cosworth turbo fit too as well as any vauxhall / volvo they are all on the small 4 bolt flange i belive. or is the metro the same bolt pattern as escort turbo t3 ?????
Posted 20 July 2004 - 10:20 PM
Bit randomn, but relevant. What about the T3 off a Rover 820 Vitesse, slightly bigger than the R5 GTT spec T3, will this make more boost and fit in the box?
Posted 23 July 2004 - 08:23 AM
Lol Ul Neva Get A Trubo Ur Dad Wnt Let u
