Posted 30 November 2015 - 06:30 PM
Just a quck one, over the past few days one of my fuses keeps blowing, the bottom one for clocks/tail-lights. Most recently 3 blew within 10 minutes!
I've recently had a radio installed, although it went a good 3/4 weeks without anything going wrong, is it a fault with the radio? Or could it be another fault?
Thanks in advance!
Jordan
Posted 30 November 2015 - 06:56 PM
Try disconnecting the radio first and see what happens.
If the problem persists then start looking for damaged wiring as a chafed / rubbd wire can cause a short.I've also heard a few tales recently that the printed circuits on the speedo can cause isues as the illumination is part of the same circuit.
Have a look aroud and employ a process of elimination.
Posted 30 November 2015 - 06:58 PM
Cheers for the help, i'll give it a try tomorrow!
Jordan
Posted 30 November 2015 - 07:02 PM
Give me a shout directly if you need more help :)
Mini Technical Sections →
Problems, Questions and Technical →
Spi Auto Keep Dying After About 15 Mins Of Driving. Ideas?Started by Lilgreenmini , 28 Mar 2026 |
Question About WiringStarted by Chekako , 07 Feb 2026 |
Timing Scatter ? Two Marks On The Pulley At The Same Time…Started by corsicanwood , 21 Jan 2026 |
Auu1086 DizzyStarted by Sharks , 09 Sep 2025 |
Broken Headlight Stalk On InnocentiStarted by IceBlue , 25 Aug 2025 |
