Heritage Bonnet Priming Fisheyes
Best Answer eean , 19 December 2015 - 07:28 PM
All sorted, bought some anti silicone additive, 50mls 7 quid, gave it 2 thick coats no problems then flatted back as there were a few marks from the steel itself showing so then gave it a final top coat, looks very nice, thanks to all who gave advice, cheers have a great Christmas ☺ Go to the full post
24 replies to this topic
#1 eean
eean
  • 161 posts
Posted 14 December 2015 - 09:01 PM
Evening, painted the bonnet tonight in celly primer, the bloke I bought the bonnet from warned me re the paint fisheyeing as his mini was full of fisheyes, he was flatting the wings down as I turned up to buy the bonnet, it was a full heritage shell build he was doing but selling the doors and bonnet as he wanted to use the original ones from his Cooper S, anyway, I gave it a good wet flatting down, panel wiped then primed, loads of fisheyes, I was expecting a few but there's loads.Do you think it's the kind of primer they have used, it is quite thick over the black coating? I was planning on flatting again and trying another coat but thought I'd ask,NB I did the boot lid at the same time and this did not happen so I def know it's something to do with the original primer coating
#2 Carlos W
Carlos W
  • 10,115 posts
Posted 14 December 2015 - 09:09 PM
Fish eyes are usually caused by silicone
#3 littlewimp
littlewimp
  • 104 posts
Posted 14 December 2015 - 09:43 PM
as above.
#4 corrado vr6
corrado vr6
  • 678 posts
Posted 14 December 2015 - 09:46 PM
I got fish eyes in a mini door once after spraying with a diesel heater on in the workshop.
I guess the only real way to sort it is to go back to bare metal
#5 David128
David128
  • 644 posts
Posted 14 December 2015 - 09:47 PM
clean with panel wipe then redo
#6 eean
eean
  • 161 posts
Posted 14 December 2015 - 10:01 PM
Ok so flat back, panel wipe then re prime or strip it to metal?
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 December 2015 - 10:06 PM
Strip back to bare metal, degrease it and then prime
If there is silicone in the paint that is on the panel then panel wiping it will make no difference.
#8 midridge2
midridge2
  • 1,794 posts
Posted 14 December 2015 - 10:12 PM
Or use anti silicone adertive.
#9 jonjosar
jonjosar
  • 137 posts
  • Local Club: Not yet
Posted 14 December 2015 - 10:15 PM
The silicone could have been in his airline/compressor/spraygun so as Ben_0 says, strip it back.
You could try isolator,  if your still having problems, then  start with a light coat no matter what your priming with. A heavy coat seems to exacerbate the problem.
#10 eean
eean
  • 161 posts
Posted 14 December 2015 - 10:20 PM
Ok thank-you for all input, I'll strip it off
The weird thing is the curved front part of the bonnet doesn't seem to be affected, just the majority flat parts, its factory applied grey over the black stuff so god knows what's been used
#11 sledgehammer
sledgehammer
  • 3,132 posts
Posted 14 December 2015 - 11:08 PM
some deodorants have silicone in them & some fabric conditioners
wonder if anyone has ever sprayed with an auto lube in the line (not saying OP has)
or used a dirty air line (air line connected to auto lube on ratchet , when released at wall , air & oil vapour rushes into the pipe
pipe now has oil vapour in it
Edited by sledgehammer, 14 December 2015 - 11:11 PM.
#12 eean
eean
  • 161 posts
Posted 15 December 2015 - 07:26 AM
Don't known but this seems that way, the bloke I got it from bought the complete heritage shell and it all came in this thick grey primer over the black stuff, wouldn't like to have bare metalled a whole shell lol
#13 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 December 2015 - 07:56 PM
If the bonnet was laid flat when the paint was applied, sillicone in the air might have landed on the paint. It might explain why only the flat part was affected
#14 eean
eean
  • 161 posts
Posted 17 December 2015 - 08:14 PM
Well, I bare metalled it, I can't believe how much paint was on it, I 320 DAd it, I panel wiped it thoroughly, it states on the can it is a professional degreaser for paint prep etc, I etch primed, left it over night then primed tonight even worse!!
So I wiped it all off with thinners, went to the paint shop and got some fresh panel wipe, they explained that's all they sell to degrease, so DAd it again, panel wiped 3 times and etch primed only thin mist coat, let it set and dry properly then primed, still had a little bit of fisheye, so lagged the rest of the primer on I had left after flashing off and it seems OK?! Mental, never seen nowt like it, am going to leave over night then flat it and give it a light top coat before a good coat then leave it and see what happens. What a pain in the rear!
#15 midridge2
midridge2
  • 1,794 posts
Posted 17 December 2015 - 08:43 PM
Should have used anti silicone addertive, you still have silicone in the primer coat.
