Drum Font Brakes ...can I Put Any Alloys On
15 replies to this topic
#1 biker1981
biker1981
  • Just Joined
  • 303 posts
Posted 19 December 2015 - 07:10 PM
I have just bought a 1982 mini and it has drum brakes at the front ..... I just wondered can I stick any mini lite wheels on the front or are you restricted having drums.
Should I upgrade to discs at the front is it. Big job pls?
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,032 posts
Posted 19 December 2015 - 07:16 PM
You can put what ever wheels you like on drums.
What wheel size have you got/fitting? if it's 12"+ then 8.4's will do the job. If you buy the complete unit ( discs, hubs, cv joints etc) then it is a case of splitting the ball joints and track rod ends, removing the drums and cv joints, fit the disc assembly re-plum the system and bleed it.
#3 carbon
carbon
  • 2,590 posts
Posted 19 December 2015 - 08:13 PM
The standard drum brakes have a different wheel offset to disc brakes. If you use alloys which fit over disc brakes then most of these will require use of one inch spacers both front and rear (either separate spacers, or the wider 'superfins' with cast-in spacers) plus longer wheel studs.
You may be able to fins some alloy ten inch wheels which were originally intended for use with drum brakes, but these are probably getting a bit thin on the ground these days.
#4 Cooperman
  • 23,308 posts
Posted 19 December 2015 - 08:19 PM
The 'reverse rim' wheels were designed to allow wider wheels on drum braked cars without spacers being necessary. So wheels with the Cooper 'S' datum offset will not fit as the tyres will hit the dampers. On the rear it is easy to just fit 'S'/Mayfair type spacered drums, but on the front longer studs and spacers are necessary. Alternatively, just buy wheels with the correct offset or fit a set of disc brakes.
The 997/998 Cooper also needed spacers to fit 'S' wheels despite having disc brakes.
#5 1984mini25
1984mini25
  • 8,785 posts
Posted 19 December 2015 - 08:27 PM
Not if you buy a complete hub, calliper, disks, hoses (disk brake ones are shorter and the drum ones will foul the tie bars if used) and driveshaft's (the disk brake ones are thicker) assembly from a donor mini. Then its a case of swapping them over and bleeding the brakes.
#6 biker1981
biker1981
  • Just Joined
  • 303 posts
Posted 20 December 2015 - 09:38 AM
I think I will just put 1inch spacers then some 12" alloys. So can I confirm this will work ok ?
#7 Tommyboy12
Tommyboy12
  • 2,254 posts
Posted 20 December 2015 - 10:23 AM
Not likely. If you use a thick spacer you'll probably need longer wheel studs. Although that's not too long a job to change them. Take the hubs off, knock the old studs out and knock the new ones in.
#8 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 20 December 2015 - 10:49 AM
a lot of wheels will just bolt onto a drum braked mini
it's the clearance on the inside of the wheel you will have to check as the wheel will stick in more than on a disk braked car
#9 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 20 December 2015 - 11:52 AM
i had Dunlop d1's on my drum braked car.
#10 gazza82
gazza82
  • 3,017 posts
  • Local Club: TMF+
Posted 20 December 2015 - 02:34 PM
I'd fit the wheels then see what spacers you need. The narrower the better ... Avoids stress on the hubs/bearings/etc.
#11 1984mini25
1984mini25
  • 8,785 posts
Posted 20 December 2015 - 05:30 PM
 You can get 1" thick spacers with screw on wheel stud 'extenders' but anyone who fits and uses those needs there head looking at imo.
#12 Ethel
  • 25,991 posts
Posted 20 December 2015 - 05:48 PM
Changing studs on a drum braked car isn't difficult, I can't think of a reason why you couldn't put spacered rear drums on the front also - as long as they're new, as the shoes are wider. You can use drum drive-shafts, they are thinner, but all outer CV's are interchangeable.
#13 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 20 December 2015 - 05:56 PM
just fit a set of spacer drums front and rear
#14 biker1981
biker1981
  • Just Joined
  • 303 posts
Posted 28 December 2015 - 05:55 PM
Thanks all... I'm going to buy 1 inch spacers. What size studs should buy please ?
#15 Cooperman
  • 23,308 posts
Posted 28 December 2015 - 09:26 PM
1" longer than standard ;D ?
