Clutch Kit
Posted 20 December 2015 - 03:13 PM
Also frpm mini spares there lightened flywheel.
Will I have to balance these?
Thanks for any help cristianomitaly
Posted 20 December 2015 - 03:32 PM
Posted 20 December 2015 - 04:39 PM
Yes. Its written on their site tha tyou have to balance the fly and pressureplate toghether.
Posted 20 December 2015 - 06:46 PM
Can I do this at home.
Or take it to a mechanic?
Posted 20 December 2015 - 08:12 PM
No, sadly you can't balance it at home, or just take it to just any mechanic, however competent, because specialist equipment is needed. You need to find a machine shop that can do static and dynamic balancing. An engine reconditioners is a good place to start asking, especially one that does tuning and performance upgrades.
The process can be thought of as being similar to balancing a wheel when you have a new tyre fitted. Indeed, the same balancing machine might do the job, if there was some way of mounting the flywheel assemply accurately on it. The difference is that when balancing a wheel and tyre, weights are added, but when balancing a flywheel, netal is removed by drilling or milling in the correct places.
Posted 20 December 2015 - 11:45 PM
I shall look in to finding one here in italy.
Regards cristiano
Posted 21 December 2015 - 10:16 AM
Posted 21 December 2015 - 12:26 PM
Just so you know I changed my clutch on mine and the pressure plate and they didn't need any Balancing they were a straight for and works perfectly
Did you check the dynamic balance?
On a verto , mine have been out as much as 27 gram, not something you want on a bit of a performance engine!
Posted 21 December 2015 - 12:35 PM
Did you check the dynamic balance?Just so you know I changed my clutch on mine and the pressure plate and they didn't need any Balancing they were a straight for and works perfectly
Was the bottom end balanced with the pulley and flywheel before hand? As that's a fair amount to be out.
Posted 21 December 2015 - 02:36 PM
Nop, new flywheel with a new pressure plate.
Went preverto shortly after so the whole kit is for sale ( shameless advertising lol)
Posted 21 December 2015 - 02:48 PM
Thanks tiger.
Regards cristiano
RAMI in Reggio Emillia.
Posted 21 December 2015 - 10:13 PM
Nope, had nothing balanced at all, haven't had any vibrations at all
Posted 21 December 2015 - 11:35 PM
With all respect, but I wouldn't advise it on a public forum that way. When fitting a new pressure plate one should atleast check the dynamic balance. I think we had a case of this on the forum not too long ago?
Posted 22 December 2015 - 12:38 AM
Nicely done! Price?
Posted 22 December 2015 - 10:31 AM
Edited by Steve220, 22 December 2015 - 10:32 AM.
