Do not strip it out until you have checked for contaminants in the oil......
Drain the oil in to a clean (only clean if you would eat off it) drain pan, then take a good look at the sludge if any in your oil if there is no silvery flecks in your oil then you have NOT destroyed your engine bearings.
so what is next..... did you also notice a slight increase in the water temperature ? when you built the engine did you get it to a rolling road ? then you need to get it to a Mini based rolling road as I suspect you have retarded ignition.
However if you find lots of flecks and you didn;t get a slight increase in your water temperature then yes you will have to strip it out for a rebuild as stated above.
So when I drained the oil there were more flakes than usual on the plug for sure but I didn't see any silvery flecks. In addition my water temp was steady 100% didn't change at all. Unfortunately I am located in the USA and there are no mini specific rolling roads here. In addition the dynos that are around us only understand domestic motors like mustangs and carbed motors are like Chinese to most of the shops. ![]()
