The lower the car goes, the greater the negative angle. Thats how it usually works on Minis so it could be too high or t could be other things throwing it off. Im no expert on suspension so this is where my knowledge runs out.
Yeap and conversely, the higher it goes, the more Positive it will become.
As standard minis left the factory with up to +2 degs of camber, that was within acceptable tolerance.
Vinay, as Alex mentioned, they have positive camber from the factory at standard ride height.
When the suspension is set to standard ride height, the drive shafts will be flat or parallel to the ground.
Hi Steve,
No, I never actually measured the positive camber but everyone who has seen the car says that it looks like the tops of the front wheels are bending outwards. Is it possible that the camber is at acceptable levels?
Also is there a simple way to measure the camber using something like a spirit level or protractor?
Thanks,
Vinay
You can use a level and a protactor together to get an actual angle, or just the level on it's own to see in fact if the suspension positive, just you won't know exactly by how much.
You can make a gauge, simple, here's mine;-
As you can see, if measures to a very fine angle.
Also Raising it will make the steering go Toe In, so unless that's been set with it at the height you have the ride set at, moving forward will make the wheels steering in to each other and so give the wheels more positive camber, as well as scrubbing the tires.
Rub your hand over the tread both ways, if it feel 'sharp' as you move your hand from the inside to the outside, then it has too much Toe In.
