I am planning a 1380 - 7 port engine (specialist components head with ecu)
The car is an Spi so I need to meet the spi emissions figures here in Sweden.
CO must be within 0,5
Specialist components recommend the calver RE13 cam which is similar to the 285/Kent286, as i understand these are too high lift and lumpy for the emissions levels i want. Speaking to SC about my needs they recommend a cam with 260 degrees. is this a bit tame?
I have looked at the minispares evolution001 cam
SEAT DURATION ON INLET 264 AND EX 268
CAM LIFT IN 264 EX 289
VALVE LIFT IN 327 EX 358 STD
VALVE LIFT IN 393 EX 430 1.5 LIFT
should be timed in at 107degree or
This to me seems appropriate for my needs, but will it really get the best out of the engine?
If you couldn't tell already I am struggling with a lack of knowledge so any help appreciated.
