Hi all,
A new year and a new fault with our Rover Cooper Sport MPI.
Whilst driving and at random times the car suddenly looses interior power and the engine tries or does stall.
The headlights stay on but the engine and the heater/wipers/electric windows all cut out for a second or 2 before power is restored and everything returns to normal.
The car starts perfectly and will sit and idle quite happily. On some journeys the fault does not occur at all. It is not caused by bumps so It not something obviously loose.
The fault started to occur after I removed the cigarette lighter. This was wired into the fuse box on the AUX fuse, and earthed to the body. I removed the wire from the fuse box and the earth from the body. I do not see how this could have caused the problem?
I have checked the fuse box several times and all the fuses are ok. If it was a fuse problem surely the fuse would blow and power would not return? Instead power is lost for a couple of seconds at most and returns without any intervention.
I am not sure where to start with this fault. I has to be something loose that causes power to cut out intermittently. It is not a frequent issue. Sometimes it happens pulling off the drive, other times when miles into a drive.
Has anyone experienced anything like this before?
