I have recently purchased a mini engine off ebay for a first mini project, it was advertised as a 1275gt engine. I have tried doing some research on the engine to confirm that it is definitely a 1275gt as stated. I have listed below various numbers/identifications that I have found on different parts. I have already done some research on the internet, but so far unable to find anything which matches up exactly to what I have got. If anyone could help me identify that would be great.
Engine: BHM1442N
Cylinder head: 12G940
Flywheel housing: 22G 1921 D1268
Gearbox casing: A/BZ 4 DAM
BC&M 3220
Crank: DAM 6232
Differential crown wheel: 22 A 411
18/62
Laygear shaft: G 927
I also believe the carburetor is a HS4 from comparing it to photographs online.
Thanks,
Fordy
