Slow Cranking After Head Gasket Change?
37 replies to this topic
#31 sledgehammer
sledgehammer
  • 3,108 posts
Posted 17 January 2016 - 09:38 PM
wonder if there is a break in the cable itself , but the insulation is in tact
seen it before on welding cable - cable burns at a weak point , but insulation looks ok
#32 mikeynphoto
mikeynphoto
  • 21 posts
Posted 17 January 2016 - 10:08 PM
Good call pete, i will check..
Will get two new earth straps and see!
#33 jsor26
jsor26
  • 64 posts
Posted 17 January 2016 - 10:29 PM
the wire will stretch if it has an internal break
#34 CityEPete
CityEPete
  • 3,920 posts
Posted 18 January 2016 - 10:48 AM
I only use the bare braid ones.
#35 mikeynphoto
mikeynphoto
  • 21 posts
Posted 16 February 2016 - 04:23 PM
New starter, new earth strap.. very slightly better but still slow and not wanting to start... losing my mind...
#36 ukcooper
ukcooper
  • 1,625 posts
Posted 16 February 2016 - 06:03 PM
Find a set of jump leads.
Hand brake on put in neutral.
Take battery out or disconnect if you have another battery.( make sure the terminals do not touch the body work)
Disconnect the main cable + to the starter and then connect the + cable of the jump lead to the live side of the starter( do not connect to battery yet)
Take the - cable and connect too the engine block and then the battery.
FINGERS OUT OF ENGINE BAY
Touch the live cable on the + terminal of battery and it will turn over.
if it turns over slow just check again with a known good battery.
report back.
#37 mikeynphoto
mikeynphoto
  • 21 posts
Posted 10 July 2017 - 02:39 PM
UPDATE** SOLVED
well, it has been a LONG time since ive had time to work on the car, but with a new house move done and a nice new driveway which is a pleasure to work on ive been hard at it, anyway this is what ive done...
New Terminals on the Battery end, with new earth strap fitted in the boot...
New (second) earth strap fitted between gearbox and body shell...
New HT leads,
Full long recharge on the battery...
and... SHE`s ALIIIIIIVVVEEE !!!
thank god for that!! haha.. took me long enough too!!
Thank you all for the help!.. it was a mixture of everything suggested!
#38 mikeynphoto
mikeynphoto
  • 21 posts
Posted 10 July 2017 - 02:41 PM
p.s i had a problem with the throttle cable getting hot, it was earthing out, which made me change the mounting point on the engine bay earth strap.. this solved it and after a good battery charge all was well!...
Now on to getting it set up nice and running as good as poss!
