Ok I managed to get a picture of the arches today with a 215 wheel and tyre lined up with it and will need a 5" wheel arch:
Posted 18 January 2016 - 09:21 PM
Posted 04 February 2016 - 01:22 PM
I have decided that the rear brakes need to be equally as good as the front brakes for my mid engined mini and here is the Wilwood 8729 caliper arrived from Burton Power:
We removed the front caliper to try and size up with some Vauxhall Adam rotors (257mm diameter and 21mm vented rotor):
The caliper should hopefully get mounted ahead of the axle line leaving space for the original sierra caliper to be modded for handbrake only nearer MOT time in the summer
Posted 04 February 2016 - 01:25 PM
Here you can see it just about squeeze under the 13" wheel:
Posted 09 February 2016 - 09:12 AM
I have two calipers on the rear of mine, ford caliper is purely handbrake, I had intended to fit a fly off hydraulic lever in the cabin but just never got around to it, the braided pipe is there to do it just cant seem to find the drive to complete it.
Can I ask are the Adam rotors a snug fit on the central part of the hub? Just looking at the fit around the studs it looks a bit sloppy.....
Posted 09 February 2016 - 09:50 AM
Then off to brands for a dust off:
The 175 Yokohama A539 are ok for the road but not nice on the track and clearly not enough grip to cope with, so this needs to be sorted soon:
that photo is excellent
Posted 10 February 2016 - 11:04 PM
Posted 10 February 2016 - 11:06 PM
Posted 19 February 2016 - 05:54 PM
Ok some updates today. Firstly these goodies turned up:
And the rear wheels finally ready as I had to wait a bit longer for the diamond cutting on the rim:
Posted 19 February 2016 - 05:56 PM
Some significant difference between the 13 x 7 with 175/50/13 and 215/55/13. Hoping for a little more grip....
Posted 19 February 2016 - 06:01 PM
Now to make improvements to the fuel system and would appreciate any feedback as I only have basic understanding. Here is my current set up:
And the new proposal is as follows:
To enable me to go in and out of the fuel rail, I need to connect this fitting on the fuel rail to 8mm hose so no idea how to get this part!:
Posted 19 February 2016 - 06:50 PM
Had same issue with the fuel rail easiest way is to replace the fuel rail for one that you can fit the proper fuel connections tooNow to make improvements to the fuel system and would appreciate any feedback as I only have basic understanding. Here is my current set up:
Posted 19 February 2016 - 07:47 PM
Do you happen to have the old fuel rail to hand as I found this but no idea how it would mount:
http://www.ebay.co.u...~AAAOSwMpZUos1G
Posted 19 February 2016 - 08:02 PM
Posted 20 February 2016 - 08:03 AM
You'll get a lot more grip with those bad boys......
Posted 08 March 2016 - 09:31 PM
A few small updates to make and hoping for more progress over the next few weeks.
This is version 2 of the brake mounting brackets for rear 4 pots:
And thanks to custom minis a photograph of the wheel arches which they are posting tomorrow:
