So what do I do now ? I have to weld on my scuttle panel, wings, a panels, I know no one who can weld. Do I buy a spot welder for hundreds of pounds ?
Pete
Edited by pete l, 17 February 2016 - 12:15 PM.
Posted 17 February 2016 - 12:14 PM
Posted 17 February 2016 - 12:24 PM
Posted 17 February 2016 - 01:13 PM
Posted 17 February 2016 - 01:14 PM
Posted 17 February 2016 - 01:16 PM
None of us could weld to start with. It takes hours of practice to get as neat as some of the welding you see on here. Buy some scrap steel sheet or use old body panels make sure it is clean and practice. The Mig Welding Guide is online an excellent source of info. Buying a spot welder won't solve your problems as some of the areas are too inaccessible to spot weld.
Posted 17 February 2016 - 01:32 PM
There are innumerable instructional videos available on YouTube. I spent hours viewing them to learn how to weld. That plus proper preparation and practice will enable you to gain the requisite skills. I started from a base of zero knowledge, purchased inexpensive MIG and spot welders, and proceeded to completely rebuild my badly rusted mini.
Posted 17 February 2016 - 01:55 PM
OK, thanks for that. I am using gas.
I have all the old panels so i guess i better get out there and practice.
Pete.
Posted 17 February 2016 - 02:00 PM
Neither can I, but that is all set to change. Got some old panels and sheet steel to practise on
Posted 17 February 2016 - 02:10 PM
Should I be precticing seam welding ? or spot welding ? or plug welding ?
What would be best to use for the panels ? spot ?
Posted 17 February 2016 - 02:14 PM
Post up some photo's of your bad welds and someone will be able to advise what is going wrong.......there are only a few!!!! things that could be wrong....ha ha.
In all seriousness, keep at it. No one was born a welder (although 'experts' will argue that) so practice and it will become much more natural.
Posted 17 February 2016 - 05:22 PM
You will most likely need to plug and seam weld. But for seam welding look up pulse welding and try that my pulse welding attempts end up cleaning up better then continuous.Should I be precticing seam welding ? or spot welding ? or plug welding ?
Posted 17 February 2016 - 07:41 PM
What welder have you got??? as said post up some pictures of your welds and we can go from there
Posted 18 February 2016 - 11:21 AM
Welding metal is easy. Welding rust is hard. It's all in the prep - it needs to be shiney bright and thick enough to weld to. If its not then it needs more prep!
Posted 18 February 2016 - 01:50 PM
