What re the differences between the mli and the api tanks?
Is it just that the mli tanks have a higher flowing pump?
Can i add an mpi pump to my spi tank?
Posted 23 February 2016 - 04:07 PM
Posted 23 February 2016 - 05:13 PM
MPI Tanks have 3 main differences.
And yes and MPI pump will fit and SPI tanks
Also due to the baffles the MPI tank is heavier
Edited by hankins, 23 February 2016 - 05:15 PM.
Posted 24 February 2016 - 08:37 AM
Aha!
Thanks for that!
I never knew about the baffles. I guess that is why they are recommended for performance engines / conversions so they alleviate fuel starvation and delete the need for a swirl pot?
Posted 24 February 2016 - 02:21 PM
Posted 24 February 2016 - 08:18 PM
Not that I don't believe you Hankins,
But I wanted to be sure before i splash out on an Mpi tank and pump to replace my Spi tank and pump. I couldnt find any other info to suggest the mpi tank has baffles. See the post below from Sproket in 2008
http://www.theminifo...tion-fuel-tank/
Can anyone confirm the presences of baffles in the mli tank?
Posted 24 February 2016 - 08:38 PM
So some sources say baffles, some say foam filled.
Posted 25 February 2016 - 05:29 PM
Iv always been told they have baffles. My MPI tank is heavier than my SPI tank for sure. But i have never taken the pump out of it and looked inside.
Edited by hankins, 25 February 2016 - 05:30 PM.
Posted 09 February 2024 - 09:00 PM
Sorry to kick start this thread again, but I need to check, I have used an SPI pump on my JDM, Mini
which pump should I use?
It has been part of a change to 5.5 gal tanks using the SPI pump. I’m now wondering if it has sufficient fuel pressure.
Posted 09 February 2024 - 09:22 PM
Posted 10 February 2024 - 10:52 AM
Another interesting tank thing, the tank that came out of my SPI has the pre-injection fuel flap thing on the filler neck and a screw on cap. The replacement "genuine" tank from mini sport is just an open filler neck. I read that the SPI didn't have this flap, but mine did. Sadly the quality on the filler neck on the replacement (high spots) means it doesn't seal well. Been massaging it with a hammer to try and get that improved, but thinking I'll go back to the old tank.
Posted 10 February 2024 - 02:18 PM
Posted 11 February 2024 - 11:24 AM
I replaced the fuel pomp on my MPI and cleaned the tank because there was some old fuel in it, but it has no baffles inside.
Posted 16 February 2024 - 08:49 PM
Doesn't really make any difference as the Spirit unit itself has the pressure regulator built in so what ever pressure the tank pump delivers by way of the pipework (original Spirit or higher MPI) it will bleed it off down the return line to give the circa 1bar to the injector in the Spi body.
FS
