bump stops gone!!??
davexdavexdave
, Aug 21 2006 06:34 PM
18 replies to this topic
Posted 21 August 2006 - 06:34 PM
yeah i was fidling (again) and i twisted the bump stops and they fell off?? (well one fell off so i pulled the other off) is this a problem??? they were cut down anyway.
Posted 21 August 2006 - 07:00 PM
well yes it is a problem, they are there for a reason, what was the reason for pulling the other one off?
Posted 21 August 2006 - 09:01 PM
symetrical
Posted 22 August 2006 - 03:55 PM
Posted 22 August 2006 - 06:47 PM
Lmao, love it.
What a guy.
What a guy.
Posted 22 August 2006 - 07:43 PM
*waits for Dan's comment*
Posted 22 August 2006 - 07:55 PM
will it fail anmot for this??
Posted 22 August 2006 - 07:57 PM
Yes will fail the MOT with out themwill it fail anmot for this??
Posted 22 August 2006 - 08:58 PM
Oh bugger. Mine is missing one.
Might just pull the other off. Make it symetrical!
Posted 22 August 2006 - 09:50 PM
Well something will fail when you break the suspension on a speedbump, probably your bowels first and then maybe the shocks.will it fail anmot for this??
Put them back on.
Posted 23 August 2006 - 08:20 AM
ok well i shal get new ones.
Posted 23 August 2006 - 04:26 PM
PHAHAHAHAH LOVE IT!!!
Make it symetrical!
gonna put a pedle box and steering wheel on the passenger side? sorry that was cheeky.
but still
Make it symetrical!
but still
Posted 27 August 2006 - 08:30 PM
right ordered new bump stops but it has now occured to me how do i remove the old bases now i have tore the tops off??
Posted 27 August 2006 - 09:01 PM
try holding the remaining washer with a monster pair of mole grips, or gas pliers. failing that grind it off.
Posted 28 August 2006 - 09:48 AM
there should have been a nice nut on the back of the bump stop.... holding it on....
the front one can be a pain to remove but it's do-able with a spanner and some mole grips, and usually plenty of plusgas too.
I've found the bset what to do this job is to find a large socket (i mean laaaaarge!) and bang it over the bump stop so that it grips, then on the socket put your rachet, then thorught the subframe tower poke a spanner and grip the nut. rachet away!
