Adapting The Spi Fuel Tank Venting /breathing System
16 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 February 2016 - 10:39 PM
I am trying to collect all parts and knowledge for my k1100 16 build.
I plan on retaining my SPI tank and upgrading it with an mpi pump.
Though I need to deal with the venting /breather system currently on the spi.
As I understand the tank currently has 3 lines running from  (and to it) 1- fuel 2- fuel return 3- venting/breather.
I think it is best to remove as much of the venting system as possible. this includes the charcoal canister and the purge valve. But i will still need to vent the system.
what is the best way to do this?
#2 Steve220
Steve220
  • 5,076 posts
  • Local Club: BMC
Posted 27 February 2016 - 10:51 PM
So the system vents to the charcoal canister which purges to the inlet. 2 options - You either vent it somewhere discrete, ie in the wing without the canister, or keep the system, remove the plug to the purge valve and ditch its outlet. Only downside of that option is that it's extra weight.
#3 hankins
hankins
    Mini Lifesaver
  • 338 posts
Posted 27 February 2016 - 10:53 PM
Block off the vent at the tank, remove the line from under the car and use a vented fuel cap.
#4 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
ah! as simple as that!
#5 hankins
hankins
    Mini Lifesaver
  • 338 posts
Posted 27 February 2016 - 10:58 PM
What are you doing with the Spi engine when you remove it?
#6 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 February 2016 - 11:04 PM
selling it!
#7 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 February 2016 - 11:05 PM
is it really that simple?
#8 hankins
hankins
    Mini Lifesaver
  • 338 posts
Posted 27 February 2016 - 11:11 PM
What miles has it done? It all work ok, maybe interested depending on price, no rush either.
And yes really that simple. Vented cap will be fine, but if you wish you could set up the vent similar to pre injection. Pull all the vent pipes from under the car and all the venting stuff off top of tank and run pipe from vent port out of hole to under boot floor.
#9 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 February 2016 - 11:26 PM
Super so I guess there are actually some really simple options.
Maybe you didn't notice engine is in Sweden?
#10 hankins
hankins
    Mini Lifesaver
  • 338 posts
Posted 27 February 2016 - 11:42 PM
Yeah noticed it there. This is not an issue. Cheap shipping or could collect it.
#11 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 February 2016 - 07:49 PM
it has done around 45000 miles, runs perfectly.
Gear box will need a refurb. But I think I get more for it selling it to the Swedish market
#12 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 February 2016 - 08:20 PM
The purpose of the charcoal canister is only to act as an tank breather? absorbing the smell I a assume?
What did the purge valve do? purge what?
I have heard this system being called part of the emissions system? But i guess its removal does not effect the emission out of the exhaust?
#13 hankins
hankins
    Mini Lifesaver
  • 338 posts
Posted 29 February 2016 - 07:46 AM
It doesn't effect the exhaust emissions. It is all there simply because the laws changed and they where no longer allowed to vent fuel vapor to atmosphere. Same reason SPI's have a overflow catch tank under the wing for coolant, because it wasn't allowed to overflow on to the floor anymore.
What the charcoal canister does is store fuel vapor until the engine is up to operating temperature, at that point the purge valve opens and vents the stored vapor into the manifold for combustion.
HTH?
#14 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 29 February 2016 - 06:36 PM
HTH?
Great!
I will need to check the rules /regulations to see if i need to keep it?
#15 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 07 March 2016 - 07:06 PM
I need to try and keep the system (or as much as i can). this isnt set in stone, but i guess it best to satisfy the powers that be.
So I thought I could remove the purge valve and just vent into the charcoal canister. That should be fine/safe?
Or find a way to use the purge valve. Perhaps on a timed relay, with a switch? and tap one of the throttle bodies to purge into? possible?
