Got some shineys from MITP. Drop Down Bracket for steering column, seat extenders and new 12" Mountney Steering wheel. Have fitted the steering wheel and made some MAJOR mods to it to get the horn to work.
This is it.
I have butchered a set of points to push up against the bottom to keep the supply and wired it through a relay to activate the horn. And it works!
I digress...
I have fitted the drop down bracket and have found that I needed to hang off of the column to get it to line up. Now I have read a few other forums and it looks as though I have fitted it correctly???????
I that right? If it is why does it take a lot of effort to change the angle on the column? Should I adjust anything else to release the pressure as I don't want things to go snap when I am hammering it round corners!!!!
Sorry for the long post... one final thing....
How in hell do you fit the seat extenders? Has anyone got any pictures as I am stumped on this one!!!!
Edited by Gizzum, 22 August 2006 - 07:21 PM.
