Been reading through various posts on camshaft selection and still non the wiser on which to go for....
I purchased the engine fully stripped down for a project.
I have a A+ series 1275 MG Metro engine block (looks to be standard bore), single HS4 carb and 12G940 cylinder head (inlet 35.7mm, exhaust 29.3mm).
Looking at keeping the block at standard bore, currently debating changing to a twin SU HS4 carb and work/modification to the cylinder head such as: cleaned up, porting, convert to unleaded, new valves, springs, collets, caps... and skimmed (undecided on compression ratio).
A few of the camshafts I have looked at are the Kent 266, 276, 286, and then have been pointed in the direction of the AC Dodd cam by others and from reading other posts.
I'm looking for more acceleration and 'put you back in your seat', than top end power. Also looking for something which will create a good noise.
Open to any ideas or suggestion on what to go for, and any advice in what other work to be done.
