Rev Counter Issues
33 replies to this topic
#1 westlin
westlin
  • 281 posts
Posted 13 March 2016 - 04:41 PM
I have a smiths rvc rev counter fitted to my son's 1275. Ive changed the ignition to a power spark distributor. The issue I have is one minute its accurate the next it bouncing all over the shop. I saw someone add a resistor in the feed 10k, whic I have done but has made no difference.
Any suggestions
#2 westlin
westlin
  • 281 posts
Posted 13 March 2016 - 04:46 PM
Any suggestions
#3 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 13 March 2016 - 05:26 PM
Sounds like a loose connection to me, double check your wiring....especially at the coil.
#4 westlin
westlin
  • 281 posts
Posted 13 March 2016 - 05:42 PM
Ive just checked the connection from the dist to the coil and ive connected the black wire to the white and black and the other end to the coil. Should I eliminate that link as well.
could see any loose wires though
#5 leadly
leadly
  • 779 posts
  • Local Club: [] D.C.M.O.C []
Posted 13 March 2016 - 06:13 PM
Ignore me, didn't properly read what you had written.
Edited by leadly, 13 March 2016 - 06:14 PM.
#6 David128
David128
  • 644 posts
Posted 13 March 2016 - 06:16 PM
feed and signal on correct connections?
#7 Moggyton
Moggyton
  • 1,152 posts
  • Local Club: Stone mini club
Posted 13 March 2016 - 06:29 PM
Could be a dodgy earth somewhere? I fixed my bouncy rev gauge by grinding some paint off the battery earth in the boot :)
#8 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 13 March 2016 - 07:00 PM
I had a similar problem the gauge would be fine on start up and after a short while start bouncing around like a windscreen wiper. It turned out to be where I had taken the switched live from - it didn't like the voltage stabilizer for the fuel and temp gauges. I moved to a normal unstabilized supply and it was fine.
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 13 March 2016 - 08:24 PM
... ive connected the black wire to the white and black
You said this is an RVC type tach.  There are several types.  Some have wires some have terminals.  What did you install?  Can you post a picture?
The picture below is from an MG web site and shows the wiring on back of an RVI tach.
Note the green wire.  That is switched 12V power in.
The white wire with the stripe goes to coil (-).  (Should be white/black not white/blue)
The black wire is connected to the gauge case for an earth.
The red wire is for illumination.
Note there is only one connection to the coil.
#10 westlin
westlin
  • 281 posts
Posted 13 March 2016 - 08:33 PM
Can't get a picture tonight but it has 3 terminals signal, power and earth. Signal is the white and black wire from coil, power is light green and orange and earth
#11 westlin
westlin
  • 281 posts
Posted 14 March 2016 - 05:50 PM
Ive checked the wiring tonight. No loose conections, good continuity between the white/black wire from under the bonnet to the dash. Earth is good and the 12v supply is good as well.
any other suggestions?
#12 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 15 March 2016 - 03:02 AM
The RVC tach senses voltage pulses on the coil's low tension circuit.  There can be large spikes on the low tension wiring and that is probably why some people try adding the resistor you experimented with.  Getting a resistor or a combination of a resistor and capacitor to fix the problem will be rather hit-and-miss.  I would pursue other options first before trying to filter out noise.
I have a few suggestions.  None may seem attractive at first.
If you have a set of points and condenser, fit them to the distributor instead of the electronic module.  If the tach behaves properly with points, there may be an issue with the electronic module.  If the tach still misbehaves with points, BORROW a different ignition coil for your car and try again.  Only buy a new coil if the borrowed one makes the tach behave.
Finally, if none of these things highlight the problem, see if you can find a friend whose car you can try the tach in.  If the tach fails to work in the other car, send the tach in for reconditioning or buy a similar replacement.
#13 westlin
westlin
  • 281 posts
Posted 15 March 2016 - 06:43 AM
I have the original dash gauges so am go to try that tonight at least that should rile out the gauge.
I'll keep u posted
#14 westlin
westlin
  • 281 posts
Posted 15 March 2016 - 10:38 AM
Could my issue be ballast resistor. I have 2 wires on the positive side of the coil white/ yellow and white/pink where would the resistor be and could this be an issue and how do I check
#15 cal844
cal844
  • 9,629 posts
  • Local Club: TFMOC
Posted 15 March 2016 - 10:48 AM
The white pink wire is the resistor!
