Wiring For An Auto On A Manual Mini
Best Answer Howie1000 , 20 March 2016 - 10:10 PM
Embarrassingly enough I had two HT leads in the wrong order!! It fires up fine now. Thanks for the advice Go to the full post
Posted 16 March 2016 - 02:49 PM
My mini, after its 20yr slow rebuild is almost ready! And in true mini fashion...... It won't bloody start! It's a manual 1275 Metro Vanden Plas engine, elec ignition, it's turning and turning but not firing, occasionally a pop or bang from the exhaust. The car was originally an auto, is there anything I could've missed on the wiring? I know there was something on autos to stop the car running away with itself in drive, I I don't know what it could be. All basics have been checked.
Posted 16 March 2016 - 03:54 PM
On my car (1994) the wires are white with red trace, and I liberated them from the loom, fed into the car, then fitted the switch under the dash.
Good luck.
Posted 16 March 2016 - 04:18 PM
Many thanks
Posted 16 March 2016 - 04:30 PM
If the engine is turning over on the starter as your first post suggests, it will not be the automatic inhibitor switch. The wiring diagrams show that the white/red wire is the normal wire going to the starter solenoid (or starter relay) on manual transmission cars. On the automatics the white/red has to pass through the inhibitor switch (in series) before reaching the solenoid. If your starter motor works, you have already bypassed the inhibitor switch.
Did the new engine run for you before installation? If not, how long did it sit? Were the carb(s) on it when you got it? Walk us through what you did to install it and any steps you have taken to tune the engine. Also outline briefly what you have checked so far and how you carried out those tests.
Posted 16 March 2016 - 04:31 PM
If she's turning over than that'll be fine.
Have you got power to the coil and dizzy?
Popping a ht lead off and putting a spare plug then lay it on the head will see if you have spark.
Go from there and let us know how you get on
Posted 20 March 2016 - 10:10 PM Best Answer
Posted 21 March 2016 - 12:02 AM
Thanks for posting your findings. It is always glad to have conclusions posted to a thread.
