Camshaft Wear (With Pics)
27 replies to this topic
#1 jamieburke17
jamieburke17
  • 75 posts
Posted 25 March 2016 - 11:47 AM
276 cam, done 1000 miles, ran in carefully recently sheard a pushrod, and bent the rest, is the cam scrap? Pitting on the end of every other lobe, as well as one at the end
Edited by jamieburke17, 25 March 2016 - 11:48 AM.
#2 Sheikh Pip
Sheikh Pip
  • 239 posts
  • Local Club: Sutton Coldfield Mini Club
Posted 25 March 2016 - 12:48 PM
That looks knackered to me!
Edited by Sheikh Pip, 25 March 2016 - 12:49 PM.
#3 Swift_General
Swift_General
  • 871 posts
Posted 25 March 2016 - 12:50 PM
+1. What rockers and springs are you using. What run in procedure did you follow?
#4 firstforward
firstforward
  • 824 posts
Posted 25 March 2016 - 12:51 PM
Even the cam itself is worn, I do not mean the lobes etc, where the cam runs in the cam bearings, it looks worn, was any oil getting to the camshaft area?
#5 Dusky
Dusky
  • 5,322 posts
Posted 25 March 2016 - 01:01 PM
As above. Thats for the bin, and take a very good look at the cam oil supply etc. also check main bearings
#6 racingbob
racingbob
  • 3,061 posts
Posted 25 March 2016 - 01:05 PM
where did you get the cam from
#7 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 25 March 2016 - 01:06 PM
Replace the cam and obviously replace the followers at the same time.  If you were using high-lift rockers and/or heavier springs, go back to stock springs and rocker arms.
On initial startup, make sure you have applied assembly lube with moly in it.  The startup oil should also be rich in ZDDP.  After the break in period, the oil should at least have a modest level of ZDDP which can be achieved with supplements/additives if it is not already in the oil you buy.
#8 mk1leg
mk1leg
  • 9,343 posts
Posted 25 March 2016 - 01:58 PM
did you use cam run in lube on lobes and followers...
#9 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 25 March 2016 - 02:00 PM
Scrap, use moly lube on the lobes for first start. Check valvespring poundage.
Ac
#10 jamieburke17
jamieburke17
  • 75 posts
Posted 25 March 2016 - 05:48 PM
Thanks for all the replies, I'm using double valve springs and 1.5 ratio cast rockers and north Wes mini centre re built the engine for me since when I built the engine a bearing went, when I built it I used plenty of cam lube, I expect north went mini center would have done the same and ran it in right
#11 jamieburke17
jamieburke17
  • 75 posts
Posted 25 March 2016 - 05:54 PM
And also how would I check cam oil supply? The cam journals and bearings are fine I think it's just the pic
#12 racingbob
racingbob
  • 3,061 posts
Posted 25 March 2016 - 06:34 PM
you havent talked about where you got the cam from
i know minispeed do a regrind 276 about £70
but dont know whether i would buy one those
#13 sledgehammer
sledgehammer
  • 3,109 posts
Posted 25 March 2016 - 06:43 PM
have the cam bearings moved ? - ie holes not quite lining up ,
because that looks to have been running dry-ish
looks bad for 1000 miles
Edited by sledgehammer, 25 March 2016 - 06:57 PM.
#14 Spider
  • 15,160 posts
Posted 25 March 2016 - 07:42 PM
IMO, even if the Cam wasn't run it you wouldn't see that in 1000 miles. I actually suspect the post grinding hardening wasn't done or wasn't done right.
By the way, the Cam Lobes are splash lubricated from Oil thrown off the Big Ends.
<Edit: Or it was a as a used worn Cam that was fitted >
Edited by Moke Spider, 25 March 2016 - 07:44 PM.
#15 carbon
carbon
  • 2,590 posts
Posted 25 March 2016 - 07:52 PM
OP mentions 1 sheared pushrod and others bent...
I would suggest checking for valve springs getting coil bound or something similar not right. That would seriously knacker the cam in short order.
