Crankcase Pressure
24 replies to this topic
#1 olly33
olly33
  • 758 posts
  • Local Club: 42nd Street (back in day)
Posted 07 April 2016 - 09:41 PM
Hi all,
Right so my mini has been blowing oil out the dipstick hole when I have give it a bit of stick,not so when just pottering about. They were plumbed into the carb.I decided to check the breathers and i blew through both and seemed all clear as air came out the oil cap.
I had previously cleaned out the clutch side breather but not the timing end one.
I fitted a couple of wider hoses to each breather and temporary pushed them into a makeshift catch can. Car seemed to run a bit better and after getting it up to temp I gave it some stick and on my return i had about a cap full of clear water,which I guess is condensation with some tiny specs of oil in it.
What is my best solution to make this sort of permanent,so it breathes better and takes the pressure away from the crankcase?....fit a catch tank or any other solution.
Thanks olly
#2 coopdog
coopdog
  • 4,506 posts
Posted 07 April 2016 - 10:27 PM
I'd fit a catch tank and see how it goes, if it fills it up quickly you might have to do some digging and see what's causing the blow by, tried a compression test yet?
#3 MRA
MRA
  • 7,607 posts
Posted 08 April 2016 - 10:48 AM
Hi all,
Thanks olly
How many miles has the engine done ?  is it smoking ?
Could be worn rings or valve guides.
#4 olly33
olly33
  • 758 posts
Posted 08 April 2016 - 01:15 PM
Hi waiting on the tool for the job off a friend to check compression.
Hi all,
Thanks olly
Well 78k on clock and suppose engine rebuild,2 months before buying it, but I think just the head was done,as the guy told me some months later when I queried about the build that the pistons were not changed.
#5 olly33
olly33
  • 758 posts
Posted 08 April 2016 - 01:17 PM
Get occasional bit of smoke,but very little.
#6 MRA
MRA
  • 7,607 posts
Posted 08 April 2016 - 01:31 PM
Is the smoke on start up or when driving ?
#7 olly33
olly33
  • 758 posts
Posted 08 April 2016 - 04:39 PM
Just when driving but it's minimal really
#8 MRA
MRA
  • 7,607 posts
Posted 09 April 2016 - 07:34 PM
ok so your oil control rings are working fine but your top and second may be on their way out, ie leaking pressure in to the crank case area
#9 olly33
olly33
  • 758 posts
Posted 09 April 2016 - 09:57 PM
So I may just need new rings to solve the problem after I do a compression test.
#10 MRA
MRA
  • 7,607 posts
Posted 09 April 2016 - 09:59 PM
No it needs a thorough investigation to determine exactly what is required, but in any case you cannot just fit rings without other work....
#11 ACDodd
ACDodd
  • Mini Docs
  • 2,765 posts
Posted 10 April 2016 - 09:00 AM
Not many garages do this, but a manometer pressure test on the crankcase pressure will tell you what's going on. No anything over 2inches of water (positive pressure) at 6krpm (open breathers oil cap off) means engine rebuild.
Ac
Edited by ACDodd, 10 April 2016 - 09:00 AM.
#12 olly33
olly33
  • 758 posts
Posted 10 April 2016 - 08:23 PM
Ac
Probably not much chance of getting that done then,as most garages will not of heard of one with all the new cars on the road.
Thanks for the advice tho,will be doing a compression test tomorrow.
#13 olly33
olly33
  • 758 posts
Posted 11 April 2016 - 01:53 PM
Here's my dry compression test with warm engine,1 plug out at a time with part open throttle.
155 psi, 145, 158, 155.
Think this seems ok as there is not 15psi difference?
How do I complete a wet test with the same gauge,and will this further help with my results.
Edited by olly33, 11 April 2016 - 02:19 PM.
#14 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 11 April 2016 - 06:18 PM
Olly,
You really need to whip all the plugs out and spin the engine over with the throttle wide open to get accurate results.
You can then complete a wet test by adding a teaspoon of oil down the spark plug hole of the cylinder under test.
Cheers, Steve.
#15 olly33
olly33
  • 758 posts
Posted 11 April 2016 - 08:59 PM
Olly,
Cheers, Steve.
Here's the other results with all plugs out and warm engine. 178,155,187,159 psi
Another test with small amount of oil but maybe not same amount in each hole.
197,164,191,176 all done in same order first number being cylinder next to rad.
