Could someone formally confirm what I think I've read elsewhere, as an aside, regarding half-shaft management when removing and refitting the engine ?
Until now I have always split at least the top ball joints, to give myself more room to get the Pot Joints off their clips on the diff output shafts - and often split top and bottom and ended up pulling out the hubs and half-shafts completely, which of course means opening up the pot-joints since they won't go through the subframe.
(NB Can anyone explain WHY that feature was designed into the Mini ? It appears perfectly possible to make a slightly bigger aperture so that the Pot complete with its boot will pass through ?)
I've read that it is possible just to pop the Pots off the diff, then - as the engine is raised further - move it left to get the right pot off, and right to get the left pot off ?
Is that indeed the case, is that how everyone else does it, and if so why didn't I learn this 35 years ago ?! And can you leave the radiator on its mountings and still get the movement you need ?
Many thanks in advance for your informed suggestions.
PS Much of what is written about getting the Pot Joints off their clips fails to mention that they come off really easily as long as there are TWO sources of leverage (between the diff cover bolt heads for example) spaced at 180° to each other - references to using a wedge or a big chisel miss the point.
It can be done like that but requires unecessary effort and butchery.
It's not for nothing that the original forked tool 18G1240 applies its efforts across a diameter - which tool is now available again as a copy from The Usual Suspects for about £27. Unfortunately even the Mini Spares site refers to it as a wedge, which it is decidely not ..........
Personally I use a couple of pry-bars and suitable spacers, having lost my own original 18G1240 20 years ago, but there is indeed no substitute for the pleasure in using The Right Tool.
