Just after some advise on re-fitting my rocker assembly to head after head gasket change.
The question i have that i can`t seem to get the answer to from the old faithful haynes manual is when pushing the assembly down over the bolts it gets so far before the rockers sit tight on the pushrods and stop it going down all the way ?
I would also really like to know why some of the pushrods sit higher (i don`t mean exhaust to inlet) i mean when adjusted so all are level ish there is always 1 that sits higher !
I will be the first to admit i have got a lot to learn about these old engines and have never really understood how they work, oh yeah should have said its a 1275cc A+ engine.
Are there any issues involved with timing etc after head gasket change ??
As always any help/tips or tricks would be gratefully received
