Sealing Compound?
19 replies to this topic
#16 tiger99
tiger99
  • 8,584 posts
Posted 07 May 2016 - 04:25 PM
The already mentioned butyl rubber is the same as the expensive stuff that comes in strips, and is by far the best material for this as it will not stick permanently. Just Google around for the quantity and width of strip that you would prefer. The cost should not be ridiculous.
#17 southlincspickup
southlincspickup
  • 84 posts
  • Local Club: Bomber county minis
Posted 10 May 2016 - 11:19 PM
I used blue tac lol
#18 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 11 May 2016 - 05:50 PM
Just as a note, DumDum is no longer available now for a few years, one of the things in the compound is now deemed not available !
#19 Kt1966
Kt1966
  • 232 posts
Posted 11 May 2016 - 06:10 PM
Wow, thanks for all of the comments and advice. That butyl sealant sounds like a good idea, but a quick Google suggests it's £39 for a roll......
#20 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 11 May 2016 - 07:04 PM
Most strip type caulk (which you are likely to find at the DIY center) is likely to be butyl caulk.  It should be much less expensive than 39 GBP.
Or... try eBay.  See item number 172170034146 and/or 290950111648
Search online for "butyl tape", "strip caulk", "rope caulk", or "butyl caulk".  However, with the last search phrase you may also come across a lot "liquid" caulks in application tubes.
