Hi!
Recently bought a MED alloy inlet manifold to replace my cracked manifold.
When it arrived there were quite a bit of casting imperfectons it in .
No one's perfect so I just dremeled it out.
Today I tried fitting the manifold and it doesn't even slide over the manifold studs. Compared to my old one it's visibly wider .
Does anyone know if there's a faulty batch of manifolds around? I've tried contacting them more than a week ago about the ITG filter ( if its pre oiled or not) but didn't get a reply, so I'm not too hopefull about getting one about the manifold either.
Yes, it might be solved by filing the holes, but that's not something you expect to do when you buy something from a renowned company like med. And, with it being wider , I'd think the ports wouldn't line op too well either.
Edited by Dusky, 06 May 2016 - 10:17 AM.
