Hi all my brother has a early spi cooper, It has been running ok. However the other day he went to use the car and smoke came from around the starter motor and solenoid area. So obviously took the power away by disconnecting the battery before a fire started.
Now after sorting a new starter etc the car still wont fire and the fuel pump wont prime either. When the key is turned the oil light comes on by the power one does, however the interior light works and there is the correct volts to the battery so it isnt that.
Fuses are also fine etc
Anyone got any idea? We are thinking check the wiring to the starter as that could have been damaged from being to hot etc?
Anyone got any ideas?
cheers
Edited by minimissions, 14 May 2016 - 10:20 AM.
