HI all, the Mini in question is a Cooper SPI 1995 model, I am at the stage of putting the car back together however I am having some problems with trying to get it started, it did run fine before I started the work but now its confusing my small brain ! right lets start at the beginning, The car ran and started fine before the restoration buts its had a full strip down and everything was taken out, however I did label everything up.
It is fitted with the standard immobiliser part number YMC 1028 3AS this was behind the dash, it also has a Cobra model AT 2130 box fitted behind the dash, which I assumed was an after market immobiliser or a bypass box.The immobiliser was plugged in in the normal way, but the cobra box was wired in to the loom going from the ignition switch with two wires, and then the red and white wire from the ignition was disconnected and instead a wire was run from the back of the ignition switch connected to the red and white wire but then off direct to the starter motor solenoid terminal. hence I assume a bypass. when I connect the boxes as described above, and turn the key I can hear the fuel pump and noises from under the bonnet like the injection system etc. but other than that its dead when I turn the key.
if I swap the boxes around and plug in the cobra one direct into the original Immobiliser box the car turns over on the starter motor but this is without the key even being in the ignition. I am bloody confused, so does anyone have any ideas... as I am running out of them now, I am good with mechanical stuff, I can weld, I can build engines, I can paint spray but car electrics confuses the sticky brown stuff out of me...... any help or suggestions would be happily received... Thanks in advance.
