Oil Filter £1.26 Free Postage
26 replies to this topic
#16 Matt Brighton
Matt Brighton
  • 333 posts
Posted 19 May 2016 - 07:09 AM
I just ordered x5 with free delivery for £6.33p
Thanks for the heads up ...
Matt - brighton
#17 mab01uk
mab01uk
  • 12,626 posts
Posted 19 May 2016 - 11:52 AM
if something seems like its too good to be true.... then it probably is  :dozing:
Agreed cheap is not always worth the saving in the long run, not all oil filters are the same and it is especially important on Mini's which share the oil with the gearbox.......several test reports like below if you google....
Engine Oil Filter Study
"Use this study only as a source of some information that may give you a better idea about which filter brands to steer clear from. It should be obvious that some manufacturers are not being honest about their product. The next time you buy a filter for your car, buy two and hack one open to see what you have. My intent was to give you some information and alert you to some little-known issues, not to tell you what to think."
http://www.austincc....filterstudy.htm
Edited by mab01uk, 19 May 2016 - 12:39 PM.
#18 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 19 May 2016 - 12:15 PM
Or go to their Sister Company Carparts4less.co.uk.    Even cheaper then.
Carparts4less.co.uk
Quite well known that site is about 25% cheaper. Ecp main website usually matches the prices when they do a promo event.
#19 FlyingScot
FlyingScot
  • 2,672 posts
Posted 19 May 2016 - 02:39 PM
Since they were cheap as chips, I am going to section one when it arrives....
Digging around shows that Crosland no longer make filters, the trademark name is owned by Eurocarparts themselves so what's is the box is what they decide to purchase which is probably why they are so cheap from these two sources.
FS
#20 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,231 posts
  • Name: Simon Jackson
Posted 20 May 2016 - 07:53 AM
FS
That would be interesting. There is a report on one of the Honda forums that instead of filtering the oil, it was diverting it around the filter due to poor manufacture
#21 FlyingScot
FlyingScot
  • 2,672 posts
Posted 30 May 2016 - 05:12 PM
Okay sorry for the delay, I was out of the country on business.
Filters arrived - marked Crossland L10175PS
Pictures
Attached File  image.jpeg   44.64K   6 downloads
Boxed filter
Attached File  image.jpeg   38.36K   5 downloads
Filter
Attached File  image.jpeg   39.67K   5 downloads
Top view
Attached File  image.jpeg   47.6K   7 downloads
Top cutoff showing filter paper and rubber seal
Attached File  image.jpeg   45.29K   8 downloads
Removed showing pleated paper around internal pressed former
Attached File  image.jpeg   45.37K   6 downloads
Bottom deflector plate this forces the oil from the centre to go through the filter media
Attached File  image.jpeg   48.3K   9 downloads
Sealant inside central section to deflector. Oil must come from centre section through media.
The filter paper is 1.28m2 approx in area.
Construction is well formed with centre section held tightly against outer plate by rubber o seal shown in 4th picture.
Seems pretty good to me!
FS
#22 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,020 posts
Posted 31 May 2016 - 07:32 PM
£1.26 well spent!
#23 blackbelt1990
blackbelt1990
  • 2,624 posts
  • Local Club: Minimus Maximus
Posted 31 May 2016 - 09:10 PM
ECP bought the Crossland name and now stick it on the cheapest filters they can get, rather than researching and developing their own. There's no guarantee that they'll even be the same as the ones they were selling a week ago lol.
It's the same with Pagid and Eicher, ECP own them and there's a lot of bad reviews regarding noisy disks and pads. I try to avoid the lot, bought some Brembo disks and pads for our MINI today even though they were £20 a pair more than that other two makes.
#24 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 01 June 2016 - 06:58 AM
People forget ecp is aimed at all levels of road user. They sell cheap parts, mid level and high end parts. Most people will go for the cheapest.
Someone with a 200 quid car will buy the cheapest pads n discs and a little harsher noise when braking wont matter to them.
Someone with a bmw m sport will buy performance discs and pads.
Its all about perspective and cost.
Pagid stuff has a good warranty and ive used them on my daily cars without issue. I thought i had a set of warped discs....6 months old and the swappes them over the counter without question. Turned out the hub was actually damaged/bent from previous owner which caused the issue not the discs themselves.
Repaired hub and refitted new pagid discs and 20k miles its been fine.
#25 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 08 June 2016 - 09:30 PM
I've used Crosland filters on my mini for years and never had any issues. Also got a pagid master cylinder which works a treat.
#26 FlyingScot
FlyingScot
  • 2,672 posts
Posted 08 June 2016 - 10:10 PM
I'm happy with what I bought, I hear what people are commenting, but for economic quantities it's unlikely to change so frequently between suppliers. There are only relatively few manufacturers of the filter medium too and there will be a specification from ECP.
FS
#27 Davey3legs
Davey3legs
  • 36 posts
Posted 09 June 2016 - 12:55 PM
Unfortunately, when i went to look at ordering a few of the bargain oil filters, they wanted £8 delivery,the joys of living offshore lol. Fortunately, Eurocarparts have a voucher code on at the moment 'Flash25' which makes a crossland oil filter £1.12 with free delivery, even offshore. Happy days.
