Thread Lock Or Not?
electrical
22 replies to this topic
#1 nicklouse
  • 18,596 posts
Posted 18 May 2016 - 07:09 PM
Yes the tag is correct.
Do you?
B3630503-9416-46A6-94F1-7D9EAB2BDB57_zps
#2 Alex_B
Alex_B
  • 4,573 posts
Posted 18 May 2016 - 07:59 PM
For small connections like that and especially electrical I use star washers, they dig into the surfaces helping create a decent connection and then don't come back undone on their own.
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 18 May 2016 - 08:00 PM
Generally no Loctite on electrical connections.
What you can do, after assembly, is to put a dab of RTV on the edge of the screw head.  The RTV serves to keep the screw from rotating but isn't in the electrical joint.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,037 posts
  • Name: Neil
Posted 18 May 2016 - 08:55 PM
Star washer or a spring washer for me.
#5 nicklouse
  • 18,596 posts
Posted 18 May 2016 - 11:08 PM
Thanks for the thoughts.
Interesting that thread lock does not seem to be a goer. And I can see why. Bug I was thinking of a paste version like 238 ,I think.
Might just go for a nylock on the screw as there is space. If I went for the star washer I would be concerned that any movement in the wire could impart motion on the screw. Star washer between screw head and connector, so I would think about a second between connector and terminal.
Yes the cables will be anchored close by but..... Racecar.
#6 Icey
Icey
  • 1,551 posts
Posted 19 May 2016 - 08:27 AM
Personally I wouldn't use a threaded connections at all for the reason you've mentioned - moved of the wire can act like a spanner. My personal preference is to build tails soldered onto the device (in this case a switch) and then crimped into a standard form connector (something like an econoseal or mate-n-lock depending on location).
Edited by Icey, 19 May 2016 - 08:28 AM.
#7 sonikk4
sonikk4
  • 16,037 posts
  • Name: Neil
Posted 19 May 2016 - 09:45 AM
Standard for us on aircraft to have electrical terminals connected by screw with either a star washer or spring washer. A sight more vibration than a race car.
#8 nicklouse
  • 18,596 posts
Posted 19 May 2016 - 11:25 AM
agreed but are they M3? I just don't see any benefit of locking the terminal to the retainer when it can undo it. Ok if you have loads of wires together so they cant move it becomes much less of an issue.
lock nuts  I think it will be.
#9 Spider
  • 14,880 posts
Posted 19 May 2016 - 08:18 PM
Nick, as the other have said, a (Internal) Star Washer will be fine. If you want belt and braces, then also fit a plain nut to lock it with, but I wouldn't fit a nyloc, especially on something so small as there's no 'feel' to how tight they really are.
Also, don't be temped to over-tighten as over time the copper of the crimp connector will flow and a hot connection will result.
Also also, I'd suggest finding non insulated crimps, then after crimping, solder, then heat shrink. Many of the better quality non insulated crimps are made from tube, where as all the insulated types are just folded / rolled sheet and can open up.
#10 nicklouse
  • 18,596 posts
Posted 19 May 2016 - 10:43 PM
Tube crimps are impossible to find here. The insulation will be removed and I have adhesive shrink wrap.
Will be using two star washers. One each side of the terminal. Nylocs would have needed longer screws. And as the tread has been shaped in a pressed tube part of the connector any nut is a big of a no no.
Not my first choice of termination but.
One thing I did notice when looking through the switches (with hands) these ones with LEDs on the end. Are not really what you think. Cheap plastic toggle with a thin "metal" sleeve over it. Rather than a metal toggle with led in it. Would not have lasted my gloved hands.
#11 jsor26
jsor26
  • 64 posts
Posted 20 May 2016 - 12:27 AM
solder and heat shrink, next time you touch  it will be because the switch failed
#12 rally1380
rally1380
  • 1,893 posts
Posted 20 May 2016 - 08:47 AM
I understand the argument for not using thread lock fluid and using a star washer, but would it realistically effect the electrical connection??  Surely the flat surface of the ring and the flat surface of the spade would be enough of a contact so as to not worry about the tread of the screw potentially being insulated by the thread lock?
I'm not disagreeing with what folks have suggested with star washers (that is what I would do), but looking at this from a purely mechanical view, the 2 flat surfaces wouldn't be effected by thread lock unless you lobbed a load of it all over the surfaces and thread and completely balls up the job.......right?
#13 Baldspeed Racing
Baldspeed Racing
  • 1,194 posts
Posted 20 May 2016 - 09:07 AM
I run similar toggle switches for my elec fan, push button starter and lights and none of the connections have ever come loose
#14 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 20 May 2016 - 11:55 AM
At work we avoid Loctite on any and all threaded electrical connections.  As mentioned by those above, we typically use zinc plated fasteners, bare (unanodized) tapped holes, and star washers.  On the couple of budget race cars I have worked on the threaded connections have been secured by a dab of RTV on the fastener AFTER assembly.
If you were only worried about a low level signal passing through the switch you might be OK.  However, toggle switches like the OP shows in his picture are often carrying a few Amps and that's where you don't want any non-conductive material in the connection.
#15 rally1380
rally1380
  • 1,893 posts
Posted 20 May 2016 - 03:39 PM
Ok, how about one all assembled, the OP could put a lock nut on the rear of this connection but loctite that on?  This would have zero effect on the conductivity of the of the connection would it not?
I still doubt that loctite in this situation would actually make the blindest bit of difference to the function unless as I previously stated it gets pasted all over the joint.
