How To Tune Hs4 Carb Without Lifting Pin?
Posted 07 June 2016 - 12:08 PM
Posted 07 June 2016 - 12:53 PM
Take off the air cleaner and lift the bottom of the piston with a small screwdriver. The blade width should 1/4" and you slowly rotate the blade under the piston until it is vertical. It helps to have a small mirror on a stick to see what you are doing.
Posted 07 June 2016 - 02:32 PM
Posted 07 June 2016 - 03:41 PM
Posted 07 June 2016 - 03:55 PM
Won't taking the filer off make it leaner anyway?
Only very slightly. You could set it then richen it about 1 flat and it will be OK
Posted 07 June 2016 - 06:47 PM
