How Do I Change From Positive Earth To Negative Earth With Dynamo?
Posted 07 June 2016 - 07:33 PM
Posted 07 June 2016 - 07:41 PM
Disconnect the distributor first though. Just in case ...
Edited by gazza82, 07 June 2016 - 07:42 PM.
Posted 07 June 2016 - 07:57 PM
This is how I did one a long time ago.
Connect the negative of the battery to the earth strap but don't at this stage connect up the positive. Remove both dynamo leads; the dynamo will still earth through the mounting brackets. Connect a length of cable to the positive side of the battery. Touch the other end of this cable briefly (enough to make a small spark) to the small terminal of the dynamo a few times. Your dynamo will now be repolarised. Connect the dynamo leads, connect the positive side of the battery and when you start up the ignition light will go out. What you are doing is reversing polarity of the small residual magnetism in the dynamo which is necessary to start it charging.
You may need to look at the heater motor, wiper motor, fuel pump etc.
Edited by Northernpower, 07 June 2016 - 08:03 PM.
Posted 07 June 2016 - 08:12 PM
Posted 07 June 2016 - 08:21 PM
No problem.
It should be, you will benefit from new brushes if you haven't already fitted some; make sure the springs that hold them in place are strong and more importantly make sure the gaps in the commutator are cleaned out.
Posted 07 June 2016 - 08:52 PM
Posted 07 June 2016 - 08:54 PM
Yes it is work to do inside, If its a new one you won't need to check.
Edited by Northernpower, 07 June 2016 - 08:57 PM.
Posted 07 June 2016 - 09:20 PM
Posted 07 June 2016 - 10:47 PM
Take the battery off and take it round to the front of the car. Connect the negative to the case of the dynamo and flash the positive to the terminal. That way you only need two short pieces of wire. Just make sure you have a real good earth otherwise it won't flash.
Posted 08 June 2016 - 07:25 AM
Posted 09 June 2016 - 03:54 PM
Pushing out 00.3 I put earth of battery to cover and positive to the big connector? Have I done
It right? It was sparking blue cheers Tom
Posted 09 June 2016 - 05:01 PM
Posted 09 June 2016 - 06:04 PM
Posted 09 June 2016 - 08:51 PM
