Removing Cat
Posted 03 September 2006 - 05:39 AM
Posted 03 September 2006 - 08:43 AM
And yes it will need to go back on for MOT
Edited by Mini Sprocket, 03 September 2006 - 08:44 AM.
Posted 03 December 2006 - 05:39 PM
6. Your vehicle has had its catalytic converter removed and replaced by a normal exhaust silencer but passes the emissions Test. Does it fail the MOT because it hasn't got a catalytic converter when it should have one?
a) No, if it passes the emissions part of the MOT that is acceptable.
From here
Posted 03 December 2006 - 05:54 PM
Carb engines that normally hed a cat are not so much of a problem, CO is 3.5% i think but the injection engines are 0.3%
Also the later emissions tests for the injection engines actualy shows up that the cat is not working because it fails to meet the correct CO levels.
This all depends on the guy doing the test, they can some times test the emissions on the old levels.
Posted 03 December 2006 - 06:05 PM
Posted 03 December 2006 - 06:34 PM
Posted 03 December 2006 - 06:47 PM
Mini59- what age is your car?
Edited by miniboo, 03 December 2006 - 06:47 PM.
Posted 03 December 2006 - 07:24 PM
The Mini owner claimed there's information at the back of the ruling book he looked at which concerns Minis, but if it's an injection model then it has to have a cat.
Posted 03 December 2006 - 09:15 PM
Well i've heard that a Mini owner checked all the details at his local MOT testing station/garage and apparantely a Mini fitted with a carb regardless of it's age doesn't need to have a cat fitted because the MOT tester shouldn't do the cat check only the CO check.
I've heard the same there! I've got a 1993 Mayfair and i'm going to take the cat off of that.
Posted 03 December 2006 - 10:21 PM
i did refit the cat to be on the safe side though
Posted 03 December 2006 - 10:26 PM
saves you a half-rest fee when u take it back because it failed 1st time for no cat.
Posted 04 December 2006 - 12:07 AM
Posted 04 December 2006 - 12:15 AM
when it went through the MOT this year it actualy had the dellorto on...they were going to fail it on emmisions but i had to explain to them becuase it was a early 93 mini the cat and the emissions werent so strict so they said yer ok ill go check it againt the old style graph and i still dont know how it passed maybe they were pulling a sly one
Edited by mini93, 04 December 2006 - 12:16 AM.
Posted 04 December 2006 - 09:21 AM
Posted 04 December 2006 - 01:50 PM
yet another 93 mini running carb...southam mini and metro centre actualy told me mine didnt need to have a cat
I was wondering about this because when i bought my mini (93 sprite) i found out it had failed its mot for not having a cat fitted, Guess it varies depending on who tests it
