Help With Crank Damper/pulley Thickness
18 replies to this topic
#16 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 13 June 2016 - 06:18 PM
The KAD damper will work, but you will need to modify the engine/radiator mount bracket as it will rub on the damper.  And you will need to find an alternative sensor mounting as the tooth section is not in the same place as the SC damper arrangement.  You will also need to go into the ECU and adjust the offset of the tooth as the KAD is 50deg as opposed to the SC which is 40deg.
I did find my SC damper rubbed very slightly too.  If you want pics and measurements of my SC one just shout.
Andy
Hi Andy
Can you post some pictures, I'm fitting the SC one on my 7 port conversion
No probs.
Craig, you might need to make up a custom bracket if you are going to use anything other than the SC setup.
Andy what damper did you use?
#17 nicklouse
  • 18,598 posts
Posted 13 June 2016 - 06:41 PM
Looks standard 1275/1300 one.
#18 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 13 June 2016 - 07:44 PM
As nicklouse said, a standard 1275 one.
#19 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 13 June 2016 - 08:21 PM
Thanks guys! one standard dampener ordered.
