Need A Good Affordable Torque Wrench
Posted 13 June 2016 - 06:53 AM
Need a new torque wrench to replace my brake discs ( current torque wrench is limited at 210 nm Wich isnt enough for my later 1 split pin hole cv joint)
Could someone point me to a good but affordable torque wrench? I dont fancy paying loads of cash for a wrench Ill use 2 times :/
Posted 13 June 2016 - 07:48 AM
Posted 13 June 2016 - 08:17 AM
Posted 13 June 2016 - 08:20 AM
Posted 13 June 2016 - 08:31 AM
Posted 13 June 2016 - 08:56 AM
Posted 13 June 2016 - 09:25 AM
I have the 1/2" halfords advanced wrench. Can't fault it!
Nice and cheap with a trade card too
Posted 13 June 2016 - 09:34 AM
Dusty, you'll want a 3/4" drive one for doing those and given that you are torquing to a minimum figure and then going further to line up the nut to the next split pin hole, it really doesn't need to be 'mm accurate' if you get my meaning here.
See if you can borrow one as Steve has suggested or surely one of you local hire shops will have them. Failing that, if you are torquing 'on car' make your best guess based on the length of the handle of what you may have and your own body weight.
Posted 13 June 2016 - 09:50 AM
http://www.tooled-up...atchets/186679/
Absolutely fantastic and takes any guesswork out of the job
Edited by ChopperHarris, 13 June 2016 - 09:50 AM.
Posted 13 June 2016 - 10:33 AM
Although a 3/4" one really does make the job easier, the Halfords advanced one does do the job albeit with a lot more effort required!
Posted 13 June 2016 - 10:40 AM
Is it 3/4" Drive?
The latest CVs for Discs need torquing to 197 ft / lbs.
Would the halfords one stand up to that and more to align it to the next split pin hole?
Posted 13 June 2016 - 10:42 AM
But you shouldn't be using the torque wrench to align to the next split pin hole. A breaker bar would be a far better idea
Posted 13 June 2016 - 10:49 AM
No it's 1/2" drive.
Is it 3/4" Drive?
I've used it for tightening a late CV up before, and like I said it takes a lot of effort to get it up to torque.
The Halfords one goes up to 300nm which is around 260-270ftlb so it's not really testing it's limit either. I was lucky and it was aligned perfectly when up to torque with my CV so I didn't need to torque any further but like Carlos said, a breaker bar can be used for that.
Edited by RooBoonix, 13 June 2016 - 10:50 AM.
Posted 13 June 2016 - 11:26 AM
I can't vouch for them but I've been looking for one myelf recently and was potentially going for the Laser ones from Toolstation - http://www.toolstati...e Wrench/p22733
That's before I realised the Sealey ones from Halfords we so cheap and come with calibration certs....
Edited by boy-raymond, 13 June 2016 - 04:27 PM.
Posted 13 June 2016 - 05:57 PM
Could someone link one of those halfords ones? I always Get redirected to the Dutch site for some reason
Thanks again
