Need A Good Affordable Torque Wrench
20 replies to this topic
#16 RooBoonix
RooBoonix
  • 1,225 posts
Posted 13 June 2016 - 06:38 PM
Here you go buddy: http://www.halfords....wrench-60-300nm
#17 Swift_General
Swift_General
  • 871 posts
Posted 13 June 2016 - 07:07 PM
http://www.halfords....1&storeId=10001
I have the 3/8" drive version which obviously is no good for the CV nut, but am very happy with it.
#18 Daz1968
Daz1968
  • 2,058 posts
Posted 13 June 2016 - 07:17 PM
My torque wrench only goes to 150lb/ft but I have tightened driveshaft nuts by doing up to 100lb/ft then 150lb/ft, measured the angle between the two readings then used a long breaker bar to tighten the same amount of angle again, never been a problem in about 6 years and the car is driven hard. Not a mini but similar application.
But if I wanted a torque wrench I would look at the range at machinemart like link below
https://www.machinem...rive-25-to-250/
Just had another look and this item looks good value
https://www.machinem...uk/p/040215238/
Edited by Daz1968, 13 June 2016 - 07:23 PM.
#19 mattmiglia
mattmiglia
  • 515 posts
Posted 13 June 2016 - 09:17 PM
Teng Tools, really happy with it!
#20 Dusky
Dusky
  • 5,322 posts
Posted 13 June 2016 - 09:27 PM
Got one on order :)
While you're all here : does anyone know the reason the later cv joints use a (much) higher torque figure?
I'd expect it to be the other way round (more initial torque for the multiple hole cv joint because you wont have to torque it much more to get to the next hole)
#21 Spider
  • 15,142 posts
Posted 13 June 2016 - 11:39 PM
They found that the wheel bearings, particularly with the 8.4" Brakes, needed tighter clamping, so a higher grade CV was spec'd and I've found since going over to these latest CV wheel bearing life has increased considerably.
