Hi, I've just replaced my gearbox, got it all back together and back in the car. I put all new seals gaskets plus the o ring between gearbox/engine, filled the filter and new pump with oil and put a new pressure switch in (Old one didnt work). filled with oil, started the engine and the pressure light is doing the opposite of would i would expect. It is off with ignition II on but engine not running. On with engine running but when you turn the engine off, it takes about 10 seconds to turn off. - If there was no oil pressure It would always be on or off wouldnt it?
I got the pressure switch off the 998 engine i got the gearbox off. Its green where my old one was black. Have I just got the wrong switch? Thanks
Oil Pressure
topcat
, Sep 03 2006 11:30 AM
1 reply to this topic
