Fuel Line Size For Turbo
26 replies to this topic
#1 MINI-TURBO
MINI-TURBO
  • 230 posts
Posted 16 June 2016 - 11:15 AM
hi everyone, I'm about to fit my fuel lines to my mini turbo and have been doing some research on what sizes i need to run. lots of people have run 8mm inner diameter feed and 10mm return. or 8mm inner diameter for both.
i have a roll or 10mm outer diameter in the garage which is around 8.2mm inner diameter will this be sufficient enough? with my engine spec i should see somewhere between 160-180bhp
#2 coopdog
coopdog
  • 4,506 posts
Posted 16 June 2016 - 05:44 PM
Well if your looking for that amount of power you don't want to risk fuel starvation
You need 10mm id for both
#3 jt19
jt19
  • 745 posts
Posted 16 June 2016 - 08:47 PM
I reckon the stuff you have should be fine.
The fuel reg is only 8mm usually.
My lines are 8mm anyway and it seems to work fine.
#4 Turbo Phil
Turbo Phil
  • 2,427 posts
Posted 17 June 2016 - 09:19 AM
8mm ID will be more than sufficient.
Phil.
#5 jt19
jt19
  • 745 posts
Posted 17 June 2016 - 12:37 PM
I'm sure my silicone hoses are 8mm ID and my solid copper fuel pipe is 8mm OD. It seems to work fine at the moment.
#6 Rob Gavin
Rob Gavin
  • 138 posts
  • Local Club: no
Posted 17 June 2016 - 01:52 PM
I'm running 8mm OD supply and 10mm OD return without issue although there was a recent post in which it was suggested the 10mm was overkill these days.  I'm using microbore from B&Q
#7 jt19
jt19
  • 745 posts
Posted 17 June 2016 - 04:04 PM
What boost and power you running rob?
#8 matty...
matty...
  • 605 posts
  • Local Club: Turbominis
Posted 17 June 2016 - 05:06 PM
8mm is fine for both.
#9 jt19
jt19
  • 745 posts
Posted 17 June 2016 - 05:53 PM
At the end of the day it's 6mm going into the car anyway! Lol always going to have a 'bottle neck'
#10 MINI-TURBO
MINI-TURBO
  • 230 posts
Posted 17 June 2016 - 10:03 PM
thanks for all the replies guys, I will use what i have for now then if i have any issues i will go bigger
#11 Ratty93
Ratty93
    Just On Tickover
  • 8 posts
Posted 18 June 2016 - 07:36 PM
Im running 6mm feed as normal and 8mm id for return and I have no problems running between 10 and 14 psi but haven't dyno run it to see bhp
#12 MarkyRich
MarkyRich
  • Just Joined
  • 14 posts
Posted 16 August 2016 - 03:45 PM
Ive got some 10mm OD (7mm ID) from Scewfix. will that be ok???
#13 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 16 August 2016 - 06:48 PM
If its copper pipe be aware is does work harden. It needs supporting more than genuine fuel pipe; at least every 150mm and best practice (because of the work hardening) means the ends shouldn't be unsupported otherwise over time, it will fracture.
#14 MarkyRich
MarkyRich
  • Just Joined
  • 14 posts
Posted 16 August 2016 - 07:27 PM
Thanks Buddy.
Will the 7mm be sufficient though. Everywhere i went only seem to have this size?? my set up should turn out about 160-170 BHP?
Edited by MarkyRich, 16 August 2016 - 07:28 PM.
#15 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 16 August 2016 - 07:38 PM
Thanks Buddy.
Normally you would use fuel pipe size AN6 which is 8mm. There was a K head 1460 on the rollers just after mine and he had fitted 8mm bore and it gave 155bhp on petrol and 205bhp with NOS. Have you tried the turbo forum?
