Anyone With Access To Lathe To Do My Shafts
Posted 30 June 2016 - 07:51 PM
Maybe someone on here can help who has maybe done there own, willing to travel and pay beer money.
I'm in Coventry West Midlands but willing to travel to the right person, this will probs be in the next couple of months but trying to plan ahead, thanks in advance.
Posted 30 June 2016 - 08:20 PM
I assume it's just a case of turning down to a specific diameter?
If you can get them to me I'll do it
Posted 30 June 2016 - 08:34 PM
I could do this, not machined any before though
Hi thanks Ivan, can I ask where your located.
Posted 30 June 2016 - 08:37 PM
Edited by cookie4343, 30 June 2016 - 08:38 PM.
Posted 30 June 2016 - 08:42 PM
Posted 30 June 2016 - 08:46 PM
Ok I'll keep you in mind, thanks for the offer appreciate it.I'm in Southampton
Posted 30 June 2016 - 08:47 PM
Posted 30 June 2016 - 09:42 PM
I plan to turn one end with a hole and a press fit pin on the other. When pressed together there will be a V at the join. Then weld it up an then check it for true. Turn down the weld and slide a sleeve over and weld that.
Hope that all makes sense!
Posted 30 June 2016 - 09:47 PM
That's not how I'm planning to do mine.
Yep that makes perfect sense, I'm going to try some engineering places but if that fails I will be begging everywhere.
Posted 30 June 2016 - 09:53 PM
Posted 30 June 2016 - 10:00 PM
Does anyone know anything about hardening shafts after machining new splines? This is another option I am considering.
Posted 01 July 2016 - 03:14 PM
Posted 07 July 2016 - 04:01 PM
Then the shaft goes off as a model to your chosen manufacturer, to be replicated in the proper grade of steel, with hardened splines.
Posted 08 July 2016 - 08:46 PM
Sorry for the site jump but Aband is back on the scene after 2 years away give him a pm he'll be able to help you. ps some of his shafts are on the second and 3rd engine's!
http://www.16vminicl...ead.php?t=36547
Posted 08 July 2016 - 10:18 PM
Spot on just posted in the thread.
