Oil Pressure Switch Thread And Pitch
engine
6 replies to this topic
#1 ryomini
ryomini
  • 583 posts
Posted 04 July 2016 - 10:52 PM
Hallo there
read a few posts about this but couldn't find the info I was looking for
(not for the MPI as it has a different thread I believe but for other minis up to 96 as far as I can tell)
does anyone know the thread and pitch of the oil pressure switch -
I am thinking to replace with and electronic sensor as the standard one doesn't do much more than just plug the hole ;)
#2 nicklouse
  • 18,718 posts
Posted 04 July 2016 - 11:00 PM
http://www.theminifo...ake-off-thread/
#3 Spider
  • 15,197 posts
Posted 05 July 2016 - 08:19 AM
Most are 1/8 NPT, however, if the block came from a car that originally had a mechanical gauge fitted (like a Cooper S for example) then it will have a parallel thread, of which off hand, I'm not 100% sure of the size of.
#4 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 05 July 2016 - 08:23 AM
EDIT: I got confused, this is for the oil temp sender, I'll leave it here for future searches though
1/2" bsp
.825" OD
14 tpi
Edited by Fast Ivan, 05 July 2016 - 08:49 AM.
#5 Spider
  • 15,197 posts
Posted 05 July 2016 - 08:30 AM
1/2" bsp
.825" OD
14 tpi
For the switch?
#6 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 05 July 2016 - 08:47 AM
1/2" bsp
.825" OD
14 tpi
For the switch?
nope, my bad, for some reason I thought oil temp sender
#7 ryomini
ryomini
  • 583 posts
Posted 08 July 2016 - 01:53 PM
nicklouse thanks again
