Mpi Conversion
electrical engine
11 replies to this topic
#1 BugeyeandMini
BugeyeandMini
  • 27 posts
Posted 19 July 2016 - 05:46 PM
So I have two questions here.  Can a MPI engine be converted and run with a more standard SU carb? or/can a MPI engine be dropped into a non MPI mini and wired and it will run?  I know what a lot of you are probably thinking, but sometimes I get involved with things without thinking it through ahead of time.  But I have the 98 MPI engine now and I'm traveling down that road.  It is probably the same roads the lemmings take.  LOL
Any thoughts/help would be appreciated.
Terry
#2 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 19 July 2016 - 05:50 PM
Don't mean to be rude, but why bother? :tumble:
#3 JCP
JCP
  • 74 posts
Posted 19 July 2016 - 05:53 PM
As above, why? What are you hoping to achieve?
#4 ukcooper
ukcooper
  • 1,625 posts
Posted 19 July 2016 - 07:09 PM
Yes it can but as above...
#5 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 19 July 2016 - 07:24 PM
the answer is yes to both your questions
to run a carb set up you would need an inlet manifold to go with it, you would need to run something other than a dizzy as there is no dizzy hole on the mpi block so megajolt or similar. You would need an electric fuel pump. Depending on what head you use you would need to think about the plumbing and the mounting of the alternator.
To fit the entire injection set up is a lot more involved and would require everything including the loom, fuel tank, relays and ecu/alarm module and so on. But it has been done before
#6 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 19 July 2016 - 09:20 PM
If you can get hold of an ecu that works would be your first problem, and then the engine and ecu looms, which are not cheap.
It can be done, but may cost a lot more than you think.
#7 BugeyeandMini
BugeyeandMini
  • 27 posts
Posted 20 July 2016 - 04:23 PM
I appreciate everyone's response, well almost everyone's.  As I said in my original post, I already have the engine.  I'm happy with a carb setup.  I just had concerns because of the dizzyless system.
Terry
#8 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 20 July 2016 - 05:55 PM
have a read of this http://www.theminifo...megajolt-guide/
ready made kit available here http://www.ebay.co.u...=STRK:MEBIDX:IT
#9 tmsmini
tmsmini
  • 730 posts
  • Local Club: MOASF
Posted 20 July 2016 - 07:40 PM
anything is possible with time, creativity and money...
#10 Icey
Icey
  • 1,551 posts
Posted 20 July 2016 - 10:07 PM
Cheating a little though, not using the MPI ECU or throttle body! ;)
#11 tmsmini
tmsmini
  • 730 posts
  • Local Club: MOASF
Posted 01 August 2016 - 03:31 PM
Here is one that went to an extreme to fit the MPi engine:
http://www.aronline....mpi-conversion/
Took me awhile to find it again.
There is also another here in the states that installed the full Rover kit in a MK I body.
I have a picture or two somewhere.
Terry
#12 Broomer
Broomer
  • 1,771 posts
Posted 01 August 2016 - 06:41 PM
Because carbs are sheet?
Edited by Broomer, 01 August 2016 - 06:41 PM.
Also tagged with one or more of these keywords: electrical, engine
