hi, ive started to rebuild my 1275 engine for my 1275 gt.
I have stripped it to a bore block and have just brought a new cam, pistons etc.
i have also changed all the big end etc but the only problem i have is
The engine has never been in the car (i got the car without a eng) and the cam box i said that i have to keep the revs over 2500 rpm
well this mess the big ends and rings etc up when i first start it up. thats all ill need.
Thanks for looking
Thanks damian
Rebuilding new engine
dam
, Sep 05 2006 07:35 PM
10 replies to this topic
Posted 05 September 2006 - 07:35 PM
Posted 05 September 2006 - 07:40 PM
Posted 05 September 2006 - 07:51 PM
Thank you thank really helped. Thanks again.
Damian
Damian
Posted 05 September 2006 - 08:15 PM
Just to clarify, did the information with the cam say you must set the idle to 2500, or is that where the power starts on the cam..
If it's the former you are going to be very unpopular if you're driving it on the road... I've been told off by the MOT man on numerous occasions as the idle on my 1330 is about 14-1500 rpm...
Posted 06 September 2006 - 07:54 PM
That where the cam starts. its a road/rally cam. After its run in does anyone know what i should set the idle to. Thanks Damian
Posted 07 September 2006 - 07:33 AM
That's the power band you're looking at, the cam will obviously function below that... and idle should be as low as you can get it.... std minis shuld idle somewhere between 600 and 800,
Posted 07 September 2006 - 12:37 PM
JG - I think he his saying that the cam's instructions are that it should be bed it in at 2500rpm (usually for about 20mins) and whether that will cause an issue with the new main bearings etc.
Posted 07 September 2006 - 09:12 PM
yep you should run the engine at 2500rpm for the first 20mins of its life, to bed in the cam and followers using oil splash of the crank. after this, set to normal idle speed.
Posted 08 September 2006 - 11:36 AM
Thanks for the replys. will it be ok to do that rph with new big ends and con rod bearing in tho. thats the only thing i scared of. starting the engine let in run a 2500 rpm and then bang big end gone etc.
Posted 08 September 2006 - 01:26 PM
it will be better if anything it will have more of an oil flow.
Posted 09 September 2006 - 08:46 AM
in fact i did this exact thing for the first time last night. very smokey!
