So I'm changing out my A series 1275 inertia type 45D distributor engine/gearbox to a 1293 pre-engaged stater and 59D distributor engine/gearbox. Other than changing the verto clutch system, is there anything electrical wise I will need to replace as well? Or it is as simple as plug and play? I'll be using the same alternator and 2 core radiator. Thanks again everyone for the help!
From A To A+ Series Engine
MiniMoe2008
, Aug 09 2016 06:02 PM
Best Answer lrostoke , 09 August 2016 - 06:14 PM
check out this topic
http://www.theminifo...engage-starter/
Go to the full post
1 reply to this topic
