Hi
My '76 Clubman is a bit hard to select the gears ( 1, 2, 3 & 4), checked fluids and all good no leak
its a rod change gearbox
it takes me a few tries to get it in.
Anyone had similar problem?
Hard Gear Shifting
Razor
, Sep 06 2006 07:41 PM
7 replies to this topic
Posted 06 September 2006 - 07:41 PM
Posted 06 September 2006 - 07:46 PM
Your clutch needs adjusting or replacing, what type of clutch do you have fitted?
Posted 10 September 2006 - 01:48 AM
its a stock clutch from a 1100S I believe
1275cc
engine number 12YDTaH149xx
once in the gear it runs great no p[roblemos
sometimes you can just put it in the gear just like that but most of the time its a bit hard to get it in the gear, no crunches though
checked the clutch fluid, no visual leaks
1275cc
Posted 10 September 2006 - 01:56 PM
what oil are you using? do you know how many miles the box has done?
Posted 10 September 2006 - 10:42 PM
If the remote casing or its internals are worn, or clogged, you will get difficult gearchanges, especially across the gate.
Posted 11 September 2006 - 09:15 AM
not really sure, as I just bought this mini last month
How do you adjust the clutch?
Posted 11 September 2006 - 09:33 PM
To adjust, start with the return stop; pull the clutch arm away from the engine then dial out the return stop until it's about a 20 thou gap.
Next, break the locknut on the plunger, then get a body to pump the clutch a few times and hold it down, then whizz the nuts up till they touch the housing. Release the clutch, give the inner nut another 1/4 turn and lock them back up.
Go drive it about, rinse and repeat if necessary.
Posted 13 September 2006 - 04:07 AM
0.020" gap from the return stop to what?
this is my 1st time to adjust the clutch and just waiting for my workshop manual.
Anyone got a pic of step by step or this adjusting screw?
