Posted 10 August 2016 - 01:07 PM
Posted 10 August 2016 - 01:29 PM
its it all round front and back ??
Posted 10 August 2016 - 01:40 PM
Posted 10 August 2016 - 01:56 PM
I'd check the connections on the starter solenoid are clean and tight..all the cars positive feeds come from there.
Also check earth connections
Could be the extra load of highbeam is finding the weakest spot in the wiring and killing the connection.
Edited by lrostoke, 10 August 2016 - 01:56 PM.
Posted 10 August 2016 - 02:14 PM
Posted 10 August 2016 - 02:16 PM
Posted 10 August 2016 - 02:43 PM
Have you tried byepassing the switch, and putting a known good 12v supply direct to the sidelights , then main lights.
Side lights should be independent of the main lights so sounds like a bad feed to the switch.
Does the switch have Brown , Red and Blue wires ??
I'd connect a 12v to the red and see if that gives sidelights.
I missed the bit were there is no power to the switch, thats the brown wire..It's non fused direct off the battery , but should be that all the browns take a feed off the battery connection on the solenoid
Edited by lrostoke, 10 August 2016 - 02:50 PM.
Posted 10 August 2016 - 03:07 PM
Posted 10 August 2016 - 03:27 PM
Mini Technical Sections →
Problems, Questions and Technical →
Spi Auto Keep Dying After About 15 Mins Of Driving. Ideas?Started by Lilgreenmini , 28 Mar 2026 |
Question About WiringStarted by Chekako , 07 Feb 2026 |
Timing Scatter ? Two Marks On The Pulley At The Same Time…Started by corsicanwood , 21 Jan 2026 |
Auu1086 DizzyStarted by Sharks , 09 Sep 2025 |
Broken Headlight Stalk On InnocentiStarted by IceBlue , 25 Aug 2025 |
