Valve guides were offset, 37/32 so incredibly tight. Got MPi oil seals on the inlets, thinking I should have fitted them on exhausts now too.
As for leak down test, tried that but our eBay special kit has stopped working. Compression wise it was great, well over 200psi iirc
Took it out for a hard blast on the motorway, pulled great like a right train, didn't notice any smoke on hard acceleration or deceleration, but on start up had the puffing of blue smoke and haZe for 30 seconds, and when hard revving on idle, puffs out a little blue / white smoke every time.
Is it a case of having new guides that this will need running in abit? There were reamed, valves were perfect, infact the guy noted how good they were, better than rim flows apparently.
When head was off bores looked good, as you'd expect from a relatively fresh block.
Supposed to be out on the weekend for the Anglian mini run, dunno to run it now or not 😐
Edited by Midas Mk1, 25 August 2016 - 07:15 PM.
