ages and ages ago i drove off a kerb and smacked the gear selector and ever since its realy hard to select reverse and its a little stiff to change from 2 to 3 or 3 to 2. now its not really a problem as you can still change gear. just wondering what ive done and can i but a gear selector seperately and if so how much????
gear selector
davexdavexdave
, Sep 06 2006 09:42 PM
3 replies to this topic
Posted 06 September 2006 - 09:42 PM
Posted 07 September 2006 - 07:15 AM
You may have smacked the tin plate on the bottom which if pushed up will drag on the bottom of the gear lever. the alternative is you've bent the rod.
Get under the car and have a good look is the answer..
Posted 07 September 2006 - 08:52 PM
ok i will do thanks guess works thought you might know
Posted 08 September 2006 - 02:16 PM
And i have one in the garage if you need one
