Hello good Spi people
I have enjoyed trying to be helpful and point other Spi users to solutions to their problems
I have read a fair few threads and try to make a habit of keeping up to date with the Spi question section on the forum
now it's my turn once again to be stuck
I have a '93 Spi with an SW05 cam and a slightly lightened flywheel and a mildly ported head
The car starts and runs but it insists on idling at 900 and until it establishes a fairly stable idle it is prone to stumble
My thoughts are maybe the fuel filter at the rear of the car.
Also when I try to take the car for a spin it bogs down and kangaroos unless you sort of feather the throttle. I keep trying to find the answer but am stuck
If I unplug the air sensor in the air filter housing this makes no difference to the running
If I unplug the CO2 sensor idem this makes no difference to the running
the throttle cable is free, adjusted and not stiff or sticking. The throttle pedal itself moves well and there is nothing obstructing it. If I can't sort it I will have to call my mini garagist to take care of it as I am getting fed up of trying to find the solution
cheers if you can help or you want more information or a precise description of certain symptoms
